Results 1 to 10 of 16
Thread: quick way to take off bondo?
    Aug 2009
    salt lake city
    322
    how are you guys getting bondo off of your cars? the roof of my celica is skimmed and it has cracked everywhere. i want it gone and the metal repaired right. hoping for miracle cure before i pull out a hammer and chisel/da or other tedious and time consuming means.
    Feb 2010
    Cleveland, Ohio
    1,608
    Re: quick way to take off bondo?
    Quote Originally Posted by derek
    Acetone? Just a shot in the dark from my model building days...
    Sep 2010
    Albuquerque NM
    240
    I can't say acetone won't work, as I've never tried it. However, aside from moisture getting beneath it and causing it to lift, there's not much else that can make it 'easily' come off.
    If it's already lifting, your best bet is to pop it off. Get a sharp metal putty/drywall scraper and get under it, like you would a decal on a window. It may be difficult in certain spots and end up needing to be ground off, but in all honesty, there's really no easy way to get it off. Grinding or sand blasting is the 'easiest' way (and least damaging to the metal) I know if.
    Also, a skim coat isn't necessarily 'wrong'. A lot of vehicles with large flat-ish surfaces (like roofs, doors and old cadillacs) will have a skim coat if there was any body work done. Without it, there's a good chance you'll be seeing waves all down those panels. However, there is a difference between a skim coat and a layer, I don't know what you have, but if it just covering some poorly done work, by all means, get it done right.
    Aug 2009
    salt lake city
    322
    there are large chunks(6-12" pieces) cracking and flaking off leaving bare metal underneath to rust. the thickness of the chunks is about 1/16" thick. i havent seen any problems or dents with the sheetmetal on the roof yet but i know i cant just replace the bondo that has cracked and fallen off. i want it done right but am not opposed to skimming and blocking out correctly once i get this shit off. near the cracks, its easy to lift and pop them off but where it has bonded to the metal is a bit more challenging. was just looking for an easy way out.
    Feb 2011
    Three hills alberta
    134
    wire wheel on a grinder cup style. it took up to a quarter inch of mine bondo off the datsun roaster like nothing.
    Dec 2009
    Netherlands
    615
    no easy way of getting that off, wire wheel is the easiest way, make sure to do it outside..
    Aug 2009
    salt lake city
    322
    cup style wire wheel?
    like this?
    Jun 2009
    Carolina, PuertoRico
    143
    There is an easy way; THE HEATGUN :mrgreen: , just heat the paint until you kind of see it changing slightly in color and rasp; Ive done it alot of times( sorry heavent taken pics :td: ) (You can also try paint remover but the wire wheel would be an easier method than paint remover)
    Feb 2011
    Three hills alberta
    134
    like this?
    Yep they work great wear a mask lots of dust
    May 2010
    SOuthern oregon
    34
    if you have a sandblasting place local you can see if they blast with walnut shells. it will blow the bondo right off and save you a ton of time. best part is blasting with walnut shells creates zero heat so no risk of warpage
  1. Mazda 800 wagon quick tidy up.
    By VintageRotaryDecals in forum Mazda Garage
    Last Post: 03-06-2012, 06:12 AM
  2. Quick TE72 Question...
    By TEhDrifter in forum Toyota Garage
    Last Post: 09-30-2011, 06:06 AM
  3. Riding low... quick vid of my car...
    By Komeuppance in forum General Discussion, JNC News & FAQ
    Last Post: 06-22-2010, 11:10 PM
  4. Help quick! Need advice right now!
    By cid_casterwick in forum General Discussion, JNC News & FAQ
    Last Post: 02-21-2010, 03:36 AM
  5. Replies: 8
    Last Post: 11-20-2009, 08:20 PM
