Results 1 to 2 of 2
Thread: Unibody slammedness? -_-
    May 2010
    Avondale,AZ
    5
    I've never owned a unibody chassis, I want to lower my TE31 sedan for the time being until I get the time to put in x73 IRS. I found on NZ 'rolla forum you can take the bottom leaf flip it, move it to the top and remove the helper for a 6" drop, which would be nice :shock: My shop manager also suggested relocating the mount to bring the axle higher so it will sit lower. I know about lowering blocks but I want to go lower than 2" and rearching springs ($80 per spring) but this is just a temporary budget mod as it is my daily driver (I don't hit any crazy bumps).
    Any suggestions would be cool, thanks!
    -Ptown
    May 2010
    Avondale,AZ
    5
    Re: Unibody slammedness? -_-
    Already figured it out, anyone know if RA65 subframe will fit? I know x7 will but the yard by my work has a full RA chassis, thanks.
