Results 1 to 10 of 17
Thread: 1979 323 wagon, auckland new zealand
    hey guys, im a new member.
    from auckland, always had 323s, this is one of about 6 ive owned, this was my second one, and only rotary converted one ive owned, had it for about 5 years, since i was 17 years old.
    fell in loev with it the first day i saw it.
    79' 323 wagon
    sprayed in yellow, blacked out upohestery, everythings black and original, am radio, (amp under seat which runs one 4" speaker in teh standard hole in the dash with ipod cord so all is hidden)
    GSII rx3 savannah coupe steering wheel
    13x7 mogulars with 215 50 13 white writing yokohamas
    13b bridgeport s4 non turbo block
    mx5 gearbox
    b2000 lsd diff
    hardy spicer custon made driveshaft to suit
    fully adjustable 1 off front struts
    rear leaf spring, about to upgrade to ultra heavy duty rear shock out of VS commadore so nice and stiff
    When i first got it it was low on some dirty mods, it was pretty fucking ruff, the guy i bought it off got it like this
    he ended up just treating it like shit so it was kinda ruff when i bought it. wish i had restored it to its former glory, but hey, i was young!
    Im currently decideing weather to chop the modgies out to 13x11's on the read and 13x10's up front, because i have to run a 1" spacer to fit around the coil overs, the will sit flush, and run 175 50 tires so they will majorly stretched, or use 175 50 and do a little stretch on these wheels
    they will space out nicely, but still undecieded.
    opinions welcome!
    May 2011
    Russia
    17
    Re: 1979 323 wagon, auckland new zealand
    If i translate correct here is the answer
    the gold wheels are 4x114
    my car is 4x110 on the rear, and because i have s3 front hubs they are 4x114 up front .
    May 2011
    Russia
    17
    Thank you very much :tu:
    May 2011
    Russia
    17
    I like drift.How do you think motor of my car Will cope with these load? :roll:
    Quote Originally Posted by Bama Boy
    this doesnt make sense brother!
    Jan 2010
    Australia
    322
    Quote Originally Posted by Anonymous: 26 Jan, 2005
    1979 model. Standard besides 2" blocks in the rear compressed (I think) springs in the front. Has had a 5 speed box fitted too. Has white wall inserts and hubcaps off some Mazda but not sure what. Maybe someone knows...
    Can't take much credit for it as I bought it like this a couple of months ago. Big plans though 8)
    I did have this photo as the inspiration for mine for a while till I went a different direction.
    Your wagon is going to look awesome on those rims too. How did you do the S3 front end conversion? Is it the same as the S2, but with different hubs? I was considering this to get a better selection of wheels
    Hey dude, i got a factory set of s3 struts, then re vamped them, cut off spring seats, and got the weld on adjustable sleeves with cusco adjustable camber top hats, with the new shock i used a seris 2-3 shock, s1 shocks are 1" longer, but the 2 and the 3 series are that 1inch shorter, so its all set up to have tonnnnes of clearance.
    im just having trouble finding a s3 caliper re-build kit, any ideas? Im SICK of dealing with mazda, every time ive ever spoken to them, they flog me off as the car is old, and they are simply lazy.
    anyway, s3 brakes are the biggest of the rx7 brakes that came with the factory 13" wheels, i was lookin at some willwood calipers, but they were going to end up being way too expensive, and lets face it, brand new s3 stuff will be efficient enough.
    Wheel fitment wise, with the front im going to run a 25mm spacer, and the rear will have a 25mm adaptor.
    May 2011
    ireland
    10
    how much do modgies wheels cost ruffly
    Modgies are cheap, advanti do them for around $780
    brand new
    http://www.trademe.co.nz/motors/car-par ... 421878.htm
  1. 1979 corona wagon
    By biohazard989 in forum Toyota Garage
    Last Post: 05-31-2014, 02:47 AM
  2. 1979 Datsun 810 Wagon
    By ArchetypeDatsun in forum Datsun/Nissan Garage
    Last Post: 08-10-2013, 08:20 AM
  3. 1979 Subaru DL Wagon 2WD - $300 (Flagstaff, AZ)
    By nfelge in forum Ad / Auction Finds
    Last Post: 05-11-2013, 02:30 AM
  4. 73 Crown Wagon in New Zealand
    By madaz in forum Toyota Garage
    Last Post: 09-16-2010, 04:43 PM
  5. rwd sigma wagon frm new zealand
    By hypokp in forum Mitsubishi Garage
    Last Post: 01-25-2010, 03:22 AM
