Results 1 to 7 of 7
Thread: Rebuilt Transmission not Running Well, MX73
    Jul 2008
    Los Angeles
    6
    So I got my car yesterday from my long time mechanic. He replaced my old tranmission with a "rebuilt transmission". When I started the car everything worked fine, as soon as I put the gear in drive and stepped on the gas the transmission lagged so bad!!
    I stepped on the gas and it sounded like the transmission wanted to pull but there was no power at all. It's sluggish like a turtle but it eventually pulls slowly. All other gears work fine and don't slip and reverse has good power.
    Is there anything I could check for myself that might be wrong?? Also the O/D button isn't functioning. Could it be that it is missing a bit oil? I couldn't check since I got it late at night but any suggestions would help!! My mechanic said he doesn't want to deal with it so he's returning all my money back...kind of suspicious to me.
    Jul 2009
    Austin
    104
    being a mechanic i would never return ALL my money thats just silly lol. Sounds like you got a shit tranny brewski. Since you got all your money back bring it to someone else who is certified to work on trannies and get your ride put back on track. He prolly screwed up and new he did so he threw all the money back at you to keep you happy.
    Jul 2008
    Los Angeles
    6
    yeah im guessing thats what he did....found out he couldnt repair it further so he said forget it....hopefully others can give me some ideas as to what might be wrong.
    Feb 2007
    SO-CAL
    270
    sounds like the tranny is bad. Low oil would slip not pull sluggish. You'd have to rev the car like hell and then when the fluid built enough pressure it woudl bang into gear. If you want a reputable tranny shop to take it to. You can come out to American transmission here in Fontana. They rebuilt the tranny in my 72 Crown and it works like a charm. Otherwise you can pull one out of a wrecking yard and hope for the best. I'm pretty sure you have a cressida so that won't be a hard tranny to find.
    Jan 2007
    3,108
    Re: Rebuilt Transmission not Running Well, MX73
    Quote Originally Posted by tripleOGvip
    Are you sure it's the transmission and not the engine?
    Jul 2008
    Los Angeles
    6
    Quote Originally Posted by ben
    I'm sure it's not the engine....All other gears pull fine....from L thru 3, except for when in Drive.
    I read in another transmission forum that linkage might not be correct?? (They were talking about a domestic car though)
    I checked the trans. oil levels and they were low....so I added more, feels a bit better but still lags on take off.
    Thanks for the feedback guys :tu:
    Feb 2008
    Yes, it's a state.
    107
    Check the torque converter? If your engine if fine and your transmission is good, that's the only thing between them that connects the two for power transfer.
  1. Rebuilt 18rc long block
    By matchan420 in forum Toyota Swap Meet
    Last Post: 03-17-2015, 11:36 PM
  2. rebuilt aisan carb on my rt52 and need HELP!!
    By SOdrifter in forum Toyota Garage
    Last Post: 05-14-2013, 08:36 AM
  3. Anyone ever rebuilt a brake booster?
    By UtahSleeper in forum Resto Tips, Wheels & Other Goodies
    Last Post: 01-12-2012, 10:08 PM
  4. Rebuilt 20r
    By bradleys 72 in forum Toyota Swap Meet
    Last Post: 07-01-2011, 04:43 AM
  5. fresh rebuilt toyota 2M head
    By turbopoint8 in forum Toyota Swap Meet
    Last Post: 06-16-2011, 07:48 PM
