Results 1 to 6 of 6
Thread: Newbie with a N600. Battery Cable routing Q's
    Jun 2010
    Broken Arrow, OK
    9
    Hi, I just picked up a 72 N600 and I'm working my front to back to get this this sorted out. Today I worked on correcting all the wiring up front to get all the lights working. I had a couple of questions as I work my way back.
    First, the front signal lights in the grill. How are they grounded, I only have two wires on the pass. side? On the drivers side where the two leads come out of the harness for the signal bulb there is also third blue wire that has been cut; I don't know where it goes?
    I'd like to redo the battery cables as the previous owner did a half ass job. The Neg. cable just goes straight from the battery post to the valve cover. Is this right? Should there be a chassis ground too? Where would it connect?
    The positive cable has a large wire that goes to the starter and then two small gauge wires. One attaches to the harness right next to the battery and the other runs down to the silicone rectifier which is just hanging below the battery. Where should the rectifier be mounted? It has a bracket, but I'm not sure where it should be mounted. Does this wiring on the pos cable sound right?
    One last thing. Is it okay to run 6024 headlights? I couldn't find any 6012 or 6014.
    I think that's it for now, though I'm sure there will be lots more. I'm go the tackle the carb rebuild next.
    I recognize some familiar names from redpepperracing here. I'll try to get some pics of my crx and the new N600 up soon.
    Mar 2011
    Monrovia CA
    100
    Re: Newbie with a N600. Battery Cable routing Q's
    My ground is braded copper and goes to the body where the coil bracket mounts and than over to the end of the valve cover. One cable with (2) tabs off it (1) at the end and the other at the middle over the coil.
    I will look in my manuel for the other question.
    David
    Mar 2011
    Monrovia CA
    100
    Turn signal/front lights R/G goes to the fuse box.
    G/Y goes to the turn signal switch (steering post)
    The 3rd wire goes to ground.
    David
    Jun 2010
    Broken Arrow, OK
    9
    Quote Originally Posted by 8803
    David
    Okay, thanks. I assumed there should be a body ground; I took care of that one now.
    I kind of figured out what is going on with the pos. cable. There is a white wire running down the fender that goes to the rectifier; the previous owner just cut that wire and ran each end to the battery, I will splice that back together. I found a wiring diagram. It looks like the positive cable is supposed to go down to the starter and off of the starter there would be a fused white wire that would go power everything else. I need to know where that white wire goes and connects to the rest of the harness.
    Jun 2010
    Broken Arrow, OK
    9
    David
    I think the front signal lights must just ground through the grill. I don't see any ground wires for those. The unknown blue wire I had is apparently for the horn which is missing.
    Jun 2010
    Broken Arrow, OK
    9
    Quote Originally Posted by 1gencrx
    David
    Nevermind, I found the horn mounted up on the cowl. Are there supposed to be two??? I only have one, but two connectors. I guess the unknown blue/red wire up front is for optional foglights...
  1. Wtb Rust free battery tray and battery tray parts for te72
    By zakte72 in forum Toyota Swap Meet
    Last Post: 05-19-2013, 09:28 PM
  2. GSL-SE Battery
    By rx-7 chris in forum Mazda Garage
    Last Post: 10-05-2011, 05:22 PM
  3. WTB: 3tc Battery tray and 3TC battery hold down
    By TE72 in forum Toyota Swap Meet
    Last Post: 02-18-2011, 07:57 PM
  4. 197X Mazda 929 heater hose routing
    By ewokracing in forum Mazda Garage
    Last Post: 04-13-2010, 10:23 AM
  5. N600 newbie
    By rotomx5 in forum Honda Garage
    Last Post: 08-06-2009, 05:26 AM
