Results 1 to 8 of 8
Thread: 510 rear shock length?
    Jun 2010
    Somewhere in the desert, NM
    199
    Hi everyone. I'm looking for rear shock replacement for my '70 Laurel. I'm hoping the 510 rears are the same (or very close) to the length. I took mine off and measured, it's 23" from the center of the bottom mount hole to the top mount point (not the threads past). Could someone please tell me what the stock rear 510 shock length is? If very close, I plan to get the Ground Control rear coil overs.
    Jul 2007
    Sydney, Australia
    1,653
    Re: 510 rear shock length?
    Is the Laurel rear shock an eye at the top, and a pin at the bottom (like a C10/C110?)
    Jun 2010
    199
    It's like the 510's. An eye on the bottom and pin on the top. I found finally found some specs for a stock replacement shock from Monroe. It lists 21.5" length for the non-wagon, which is promising.
    Now I have to figure out the coil over spring weight... I have no idea on that.
    Jan 2009
    LaPine, or
    259
    is it lowered? if so there are other options then 510 shocks
    Jun 2010
    199
    The rear's not lowered, currently on stock shocks. The ride height is perfect for the rear, except with basic shocks, it's way too soft. The car was designed for tires that tuck into the wheel well. But now that I'm getting the rear to match the front (tires out to the fender line), the rear is too soft and scrubbing under certain cornering/acceleration/bumps. Plus I have S13 coilovers in the front, and the soft rear doesn't match one bit. So I'm looking for a coilover with a shock that is the stock length.
    Dec 2010
    switzerland
    135
    hey KC30,
    the shocks from my c30 are the same as the 510 ones
    partno.:56210-78525
    Jun 2010
    199
    Thanks for the info! That's what I was hoping. The coilovers just got shipped today, so I hope they work out.
    Jun 2010
    199
    This is a follow up in case anyone's interested in knowing the length of the Ground Control PL510 (not wagon) rear coilovers. I say this as I had previously contacted Ground Control by email asking what the unsprung length was so I could figure out if I would be able to use them in my application... I never received a response.
    Here's a reference pic of the coilovers:
    The length is 21 3/4" from the center of the bottom mount hole to the top mount point (bushing). Though I'll have to see when fitting, but it seems like this is going to be a tight tolerance to fit for what I need. Since it appears to be slightly shorter than the stock ones and I'm not sure how it'll sit yet. But if need be, the top stud has enough length that I can add some shims to get some more height to the coilover's unsprung length.
  1. Looking for information on TE27 rear shock
    By maxdout in forum Toyota Garage
    Last Post: 04-24-2014, 08:11 PM
  2. bumper shock tuck - how to?
    By marsmann in forum Toyota Garage
    Last Post: 12-16-2013, 04:06 PM
  3. Rear shock recommendations MX32
    By in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-06-2013, 09:34 PM
  4. Suspension Gurus, question about LCA vs Strut length.
    By OkieRA29 in forum Toyota Garage
    Last Post: 03-28-2012, 03:28 AM
  5. 20r timing chain same length as the upper 18rg?
    By 1977ra29 in forum Toyota Garage
    Last Post: 08-10-2010, 04:48 AM
