Results 1 to 9 of 9
Thread: Suspension question
    Jul 2009
    Austin
    104
    Suspension question
    Looking at these sites it says an ae86 front tokico strut will fit my 1979 te31 corolla.
    I find this weird considering i have read elsewhere they dont work butttt...
    all the struts i look up vary saying that a 74-82 or 74-79 or 81-86 ect... i want to know for sure before ordering. The part number is TOK-HZ3014
    can someone varify this for me thank you. :tu:
    Jul 2009
    Austin
    104
    just found out about strut inserts... im gonna go out on a limb and say this is the way to go hu... lol :roll:
    May 2009
    torrance california
    28
    yea man ive researched it a bit and being a lazy non-welder myself, heres the setup to go for; ae86 front strut tubes/ rotors/ calipers, your stock top hats, gen2 mr2 rear shocks, techno toy tuning shock adapter things, and some good springs like paraidse racing, tho i ordered mine from them some time ago and havnt heard jack squat since...
    Feb 2007
    SO-CAL
    270
    The AE86 strut case is a direct bolt on. Most guys will go that route in order to get the vented disk brakes up front. As for the struts, you'll want to do a short stroke conversion if you plan on lowering the car. Otherwise you'll be replacing struts quite often if you drive the car hard. I've blown a few sets of Tokico Blues this way. I did a short stroke AGX conversion on my Celica with coilovers and haven't looked back.
    Jul 2009
    Austin
    104
    yo bro that sux about the spring i was about to order some from them too... i found some inserts that suposedly dont require welding buttt... if they did i could weld it up or actually take a hockey puck and modify it to work as a spacer/ washer considering i dont plan on slamming my beast
    haha mposted the same time as you PERTANO... is there a writeup on this conversion?
    Feb 2007
    SO-CAL
    270
    check on 3tcgarage. We were just having this conversation a few days ago. "AGAIN". LOL!!!!
    Jul 2009
    Austin
    104
    haha ok cool... but you said the strut housing of an ae86 wil bolt up to the break assembly on my 79 rolla?
    Jul 2009
    Austin
    104
    brought this over tyo 3tc garage... thanks guys :tu: :tu:
    Feb 2007
    SO-CAL
    270
    To answer a statement you made. No the brake assembly from your 79 won't work. But that's the point of the swap to begin with. To get the better brakes from the AE86. So you use the entire setup from the AE minus the top hats. Those you will use from your TE31 or TE51.
  1. Suspension Gurus, question about LCA vs Strut length.
    By OkieRA29 in forum Toyota Garage
    Last Post: 03-28-2012, 03:28 AM
  2. Suspension Question
    By The Names Yota, Toyota in forum Toyota Garage
    Last Post: 08-22-2011, 10:02 PM
  3. TE72 Suspension Question (please help)
    By phillydoom in forum Toyota Garage
    Last Post: 08-18-2010, 04:55 AM
  4. Corona suspension question
    By biohazard989 in forum Toyota Garage
    Last Post: 11-07-2009, 12:59 AM
  5. suspension question from a noob.
    By pagong in forum Toyota Garage
    Last Post: 07-19-2009, 01:28 AM
