Results 1 to 7 of 7
Thread: 1989 Honda Integra EX16
    Feb 2007
    UK
    116
    Here's an Integra parked at the end of the world, proving that it is actually flat. Just managed to stop it in time before it went off the edge.
    It's got a 1.6 DOHC with PGM-FI. D16A2 if I recall, I'm not great at Honda engines. 125hp. Wheels aren't standard bar one on the other side which is a bright yellow spacesaver.
    Whilst I'd love to buy all this cheesy Mugen stuff, I think I'll probably just get it sorted out and leave it pretty standard. It's a good car and just needs some bits looking at - brake cables and suchlike.
    It's been out of use for a while hence the general dusty look, I'll give it a proper valet when I get it on the road, which shouldn't take that long I don't think. I like the flip-up lights and back doors combo.
    That's about it really.
    Jan 2011
    Pearland Tx.
    96
    Re: 1989 Honda Integra EX16
    DUDE! I dig that! Its absolutely awesome. I also like the Mugen one.....
    Nov 2008
    Strasburg, VA
    508
    looks like a nice complete project! diggin the period mesh wheels.
    Jan 2008
    Melbourne, Aust.
    87
    Nice!
    Investigate underneath that rear wing as soon as you can they often hide rust beneath.
    Feb 2011
    Arizona
    51
    i dont think i have ever seen one of these...
    Feb 2007
    UK
    116
    So anyway, I got this into the garage and ordered some work - new radiator and suchlike. Starting to look like it can return to the road in a few weeks.
    Only problem at the moment is the idle, it's pretty high. If you disconnect the Vacuum Advance Diaphragm and bypass it, it's fine. Not sure whether that's failure of the diaphragm itself or a symptom of something else. Any way of testing it?
    Jan 2008
    Melbourne, Aust.
    87
    Could there still be some air in the cooling system?
    I found mine extremely sensitive to this & still need to bleed it more from the bleed nipple by the thermostat & intake manifold, but also had to clean out some of the plumbing there that were filled with rust deposits after the original waterpump dissolved.
    Though now I have to replace clutch as well.
  1. 1989/90 Honda Integra XSi with only 59K miles
    By tomas6791 in forum Honda Garage
    Last Post: 04-04-2015, 11:10 PM
  2. WTB: Integra NOS power antenna assembly
    By miatadon in forum Honda Swap Meet
    Last Post: 11-16-2014, 04:05 AM
  3. New Member 1991 Integra DB1
    By in forum Honda Garage
    Last Post: 07-27-2011, 06:27 PM
  4. 1st Gen Integra- newb
    By Sheeba in forum Honda Garage
    Last Post: 08-23-2010, 11:37 PM
  5. integra sj, from the phil.
    By in forum Off-Topic
    Last Post: 11-22-2009, 05:26 AM
