Results 1 to 10 of 12
Thread: Rx2 sedan restro
    Apr 2011
    sydney NSW
    112
    Rx2 sedan restro
    Hi All,
    Just starting a new Rx2 series 1 resto.
    Bought this a little while ago and have been having trouble deciding what to do? Thought if I put it down I might not change my mind to much.
    The car was a club car from the 90ís(no rust) but rough (welds and self tapers) I want to remove the flares but not to sure how to attack it yet. I do have another donor series 2 1600 so it maybe the whole quarters but that scares me, I not good with pannels really.
    Plans - I want to drive it on the road, NA and would hit the track maybe.
    Mar 2009
    Australia
    627
    Re: Rx2 sedan restro
    Looks like a very nice clean car.
    I think the first thing you need to decide is what how you really intend using it. It looks like you really want a street car otherwise you wouldnt have chopped the cage. If it were my car and its as clean as you say it is then I wouldnt remove the quarters. I think if the quarters are truely rust free then I would graft in just the wheel arch sections from the spares car, the repair could be pretty much invisible if done right.
    Same goes for the inner front guard, I would unpick and put in a clean section. Looks like a good car otherwise. You really need to be able to weld to do the repairs. If you cant competantly weld, a good panel shop could repair those sections without too much trouble. It doesnt look like it needs much to be presentable. I like the fact it still mostly wears the original paint. I'd just touch up the factory paint on this one rather than go for a full respray myself, it adds a bit of character
    Nov 2009
    Adelaide
    416
    Ooooohhhh I like it....... :shock:
    First thing that pops in my mind is tuff street car / track warrior. I would personally leave the flares (and the front spoiler) cage and everything in, but run a traditional original interior with race seats in front and tuff ported NA motor. The green suits the car well, so as gypsy said, I would leave that and touch up where needed.
    What is the rim that is on the LHR of the car?
    Good luck with your project, keep us updated. If you need any advice or help there are plenty of good people on this forum.
    Apr 2011
    sydney NSW
    112
    Thanks
    I do weld TIG more than anything (fitter and machinist, welder by trade), panels just frustrate me.
    Cage is bolt-in alloy so thatís no problem.
    The wheel is a first gen 13 inch Simmons
    I finished another car(Group C) awhile ago and it sucks to let it sit and gather dust. It could be registered but straight cut gears and brakes that have to be hot to stop. I take it to the track but thats not too often. :cry:
    So that might explain why no flares. Not to keen on green either, I like the colour but something different would be good but you donít see to many original green Rx2ís.
    Would like a tip on where to cut the donor rear guards but? The roof has a bit crows feet happening.
    Pic of it back in the day.
    Nov 2009
    Adelaide
    416
    Mate, your RX3 looks sensational!! Now I see why you don't want a green RX2 with flares though.......
    If you want to keep the car originalish, there are some cool factory colours. Flair Yellow always looks nice on a sedan......
    Apr 2011
    sydney NSW
    112
    Thanks, your car is very impressive too
    I had a white Rx2 along time ago. It would get an original colour paint anyway.
    Mar 2009
    Australia
    627
    Its hard to advise where to make the quarter cuts without looking over the car in person. The way I see it you want to make the cut so you can dress/ treat the reverse side of the welds so they dont rust, cut them in an area which isnt going to stand out/ look odd, and finally leave as much of the original quarter in place.
    Judging by the photos I'd cut just above the factory wheel flare (right round) on the car where the metal is untouched and just inside the door jamb (past the wheel flare/ 1st jamb step). Cut a larger section off the parts car and tech screw the replacement area to the car. Finally when you are happy with the fit use a very thin cut off wheel and cut through both panels so you have a perfect welding gap and 100% conforming edges.
    I'd personally MIG it but have seen people TIG similar repairs in place. You shouldnt need much filler at all.
    Im only an amateur so take my advise with caution ! Who ever repairs it may prefer to replace the entire quarter, if they have a proper 3 phase spot welder even better. I dont think there is any right or wrong way, you can make a real mess either way and either way can rust in the future if not done right. In my opinion replacing just the wheel flare area is much less intrusive and less likely to cause future problems.
    Aug 2010
    perth western australia
    56
    Good starting point mate. Shame about the flares thou. Looks like someone put a Rx3 or Rx4 fuel tank between the strut towers in the back.
    Good luck with it.
    Apr 2011
    sydney NSW
    112
    It had a tank out of a Galant in the boot.
    Soda blasted the engine bay this week and checking how the guards fit and front trims. Need to fit the series 1 blinkers but.
    I started a monster I think? I'm now wanting to fix every little problem I see. Tunnel looks crap.
    Nov 2009
    Adelaide
    416
    RX2 tunnels always seem to cop a flogging at some point in their lives....mine had been belted around on the passenger side, presumably to clear a starter motor at some point. What strut's did the car have fitted, as I just noticed the additional holes in the strut towers?
    Are you going to use the front spoiler again? Noticed your cage is gone too.....would love to put a cage in my coupe....I really liked the race look of this car, it was mean. :twisted:
    Looking forward to watching this car progress
  1. Rx3 Sedan build
    By Ontrack in forum Mazda Garage
    Last Post: 04-29-2015, 01:40 AM
  2. 81 sedan
    By 81_te72 in forum Introduce Yourself
    Last Post: 07-25-2013, 03:46 AM
  3. '90 Civic Sedan
    By Tofuik in forum Honda Garage
    Last Post: 07-12-2012, 07:57 AM
  4. Kyo's *E7* Sedan
    By Kyo in forum Toyota Garage
    Last Post: 10-21-2011, 06:38 PM
  5. My TE Gemini Sedan
    By cute wee gem in forum Isuzu Garage
    Last Post: 11-20-2010, 06:41 AM
