Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: My AN600s
    Mar 2011
    Monrovia CA
    100
    My AN600s
    I have (2) Honda AN600's which I found in an alley. $00!! One runs and the other has no roof and a broken timming chain. I am posting this picture to draw attention to the breather tubes in the valve cover. I have never seen these on any Honda of this type. Any thoughts.
    http://i193.photobucket.com/albums/z201 ... G_0316.jpg
    Dec 2009
    sacramento
    141
    Re: My AN600s
    rather odd, the engine would only need more crank case breathing if there was a tone of blowby
    Mar 2011
    Monrovia CA
    100
    Re: My AN600s
    I have been puzzling over how to test my brakes with a totally non functional MC. Here is my solution. I am still a few brakelines away form a true test.
    I went to pick a part and got a MC from an earily Mazda. I then hacked out an adaptor from 1/2" alum bar stock.
    The resulting fitment somewhat surprized me. Everything clears and nothing was modified on the car.
    Dec 2009
    sacramento
    141
    Re: My AN600s
    NICE, pretty much what I did with my Z brakes
    Apr 2010
    Maine USA
    39
    Re: My AN600s
    For around 100.00 and a rebuild kit you can have your MC resleaved and it will work perfect again.
    http://honda600sedan.blogspot.com/
    Mar 2011
    Monrovia CA
    100
    Re: My AN600s
    Quote Originally Posted by Douglass
    This was a $20 and a few hours method of testing the overall system. It was done without hacking up the car.
    Mar 2011
    Monrovia CA
    100
    Re: My AN600s
    My solution to a to a totally damaged coil/plug wires
    This is an 80's GM DIS coil. I can be a direct replacement for Honda coil.
    I added this Ford remote TFI for fun and because it uses the points as a switch only. Very low current no wear.
    Here it is mounted in the same location as original coil. All parts came from the "boneyard" at under $20.
    Northern California
    635
    Re: My AN600s
    Very inovative. Keep them coming. :tu:
    Dec 2010
    Venice, CA
    7
    Re: My AN600s
    I can attest to the fact that the car fires right up and runs smooth with this custom ignition setup. It's a sweet solution to the problem of a dead stock coil and should provide improved performance, without the hassle of going over to full electronic ignition -- this runs off the stock points with the only modification being the removal of the condenser.
    I don't think he even had to adjust them and it started right up.
    Jesse.
    Apr 2010
    Maine USA
    39
    Re: My AN600s
    Got any part numbers on these or year make model? Great inovation for sure.
