Results 1 to 3 of 3
Thread: '77 810 hesitation,stumble
    Apr 2011
    Florida
    69
    I just bought a '77 810 wagon,with a bone stock L24 in it.I drove it home and it drove great other than it stumbling when you accelerate. I've looked all over for vaccum leaks,fuel leaks,and everthing else I know to check.It feels like a huge vaccum leak to me,once you get over about 2500rpm,it runs smooth.The valves were recently adjusted,but that doesnt mean it was done right. Any ideas?
    Aug 2009
    Los Angeles, CA
    182
    Re: '77 810 hesitation,stumble
    Quote Originally Posted by 82Supra5m
    check the intake bood after the afm.. when i bought my 77 810 had the same issue, the bood had light dry root and craked threw slightly but.. my fix was get a new roll of electrical tape and got to wraping the the ribs and and the hole boot .. all in all it worked at a cost of a half a roll of tape ... hope it helps
    Apr 2011
    Florida
    69
    I should pull it off and check the bottom of it,the top looked to be in great shape.If not,i'm thinking it could be a clogged injector. Any idea where to find a steering box,or a rebuild kit? Thanks for the help.
