Results 1 to 4 of 4
Thread: 1963 datsun p312 engine rebuild
    Apr 2008
    new south wales, australia
    54
    Hi all,
    Just in the middle of an engine rebuild for my 312 bluebird and have a question for anyone who has rebuilt a nissan E1 engine,
    would they know if the timing chain is the same as what is fitted to the datsun A12 engine .....? I have seen some infomation recently that would sugest that it may be but have not been able to confirm it...
    Any help appreciated. :lol:
    Drew.
    Jul 2007
    Melbourne, Australia
    756
    I don't believe it is...... but I have nothing other than the vague feeling i read it somewhere.... lemme check a bit more.
    Apr 2010
    AZ
    55
    Re: 1963 datsun p312 engine rebuild
    E1 Engine = 52 link chain
    A12 Engine= 54 link chain
    Beside the amount of links, the chains are identical-
    Apr 2008
    54
    cheers mate,
    I think i may have solved the problem by using a timing chain from a 1968 mgb.
    all i need to do is a few more measurements and should be sweet.
    Already have a new set of pistons 30 thou over size to go in and motor is
    being line bored & tunnell bored as we speak, or type....
    have drilled out and removed all the oil gallery plugs from the block and have new ones to go in.
    Will keep you posted, am also using a timing case cover from an mgb as it runs a rubber seal instead of the factory felt seal the nissan ran.
    thanks, Drew.
  1. WTD... datsun 1963 P312 wiper bits.
    By coronaowner in forum Datsun/Nissan Swap Meet
    Last Post: 01-02-2013, 08:57 AM
  2. 1963 datsun bluebird p312 steering wheel.
    By coronaowner in forum Datsun/Nissan Garage
    Last Post: 08-27-2012, 10:45 AM
  3. best engine rebuild kit?
    By cult colt in forum Mitsubishi Garage
    Last Post: 07-05-2012, 09:22 AM
  4. SPL213 engine rebuild
    By glarior in forum Datsun/Nissan Garage
    Last Post: 03-24-2011, 04:48 AM
  5. WTD datsun p312 parts, australia
    Last Post: 11-09-2010, 05:11 AM
