Results 1 to 8 of 8
Thread: Celeste Lancer 2000 Diff. compatibility??
    Mar 2007
    North East United Kingdom
    213
    Just wondering if anyone with experience of the Lancer 2000 or Lancer Turbo's can tell me if the rear axle or more to the point the LSD of the Lancer is compatible with the Celeste in any way?
    Many thanks.
    Chris
    Jul 2009
    New South Fails, Australia
    225
    AFAIK the EX Turbo diff is the later, stronger 10-bolt MMC diff (like Scorpions/live axle Sapporo's run), whereas the LC Lancer/Celeste runs the early 8-bolt. So you'd have to swap diffs, not just centres.
    Mar 2007
    213
    I was thinking if the track was similar on the earlier leaf suspension models I could swap in the entire axle. Would that be a more feasable task do you think?
    I have my own 'shop/garage so feel free to just give me it in nuts and bolts rather than lamens
    Chris
    Apr 2010
    philippines
    134
    track is wider than celeste
    Mar 2007
    213
    Quote Originally Posted by motorhedz01
    Ho much wider? Do you have one to hand or pages fron the worshop manual showing the dimensions, usually at the front of the Genuine Mitsubish workshop manuals.
    Jul 2009
    225
    Re: Celeste Lancer 2000 Diff. compatibility??
    You'd also have to either convert to a 4-link coil sprung rear or weld the leaf mounts onto the 10-bolt housing, as iirc LC's/Celeste's are leaf sprung.
    Re the extra track, it's only 10mm or so iirc.
    Mar 2007
    So. Cal
    108
    its about 3 inches wider (52.5 and 55.5) you still have space since the celeste body is wider.
    Mar 2007
    213
    Quote Originally Posted by jwebb2876
    I'd most likely weld on the leaf mounts, it's really only the LSD I'm after as the celeste is so light and responsive it's causing the inner wheel to spin alot on cornering.
    Quote Originally Posted by Dax
    That is easily within what the arches will allow. If I can't find a better LSD option then I think this will be the rear end I'll be using.
    Thanks guys, very helpful :tu:
  1. Mitsubishi Lancer Celeste/Fire Arrow on TV today!!!
    By steveracer in forum General Discussion, JNC News & FAQ
    Last Post: 04-05-2014, 03:32 PM
  2. Lancer 2000 Turbo...again.
    By 2000turbo in forum Mitsubishi Garage
    Last Post: 05-24-2012, 08:39 AM
  3. WTB [South Australia] EX (Box Type) Lancer diff centre.
    By A112H in forum Mitsubishi Swap Meet
    Last Post: 01-07-2012, 12:29 AM
  4. Lancer EX 2000 Turbo
    By denz74 in forum Mitsubishi Garage
    Last Post: 10-26-2011, 06:06 PM
  5. 79 LC Lancer (Celeste/Plymouth Arrow)
    By 75wagon in forum Mitsubishi Garage
    Last Post: 03-18-2011, 01:46 AM
