Results 1 to 4 of 4
Thread: 81 Celica - 22R Motor - Will not stay running
    Jun 2009
    Union, NJ
    58
    Ok, so the weather finally nice and had time to look at the car.
    Problem: car runs but will only run 6-10 mins tops then dies and will have to sit for a while before I start it again.
    I checked: Fuel getting in carb ok, did not see any vacuum leaks or disconnected vacuum hoses.
    I changed: Mechanical fuel pump, fuel filter, plug wires + ignition coil wire, new battery, cap, rotor, air filter too
    I was asked on another forum if ignition coil overheating, did not notice to be too hot, but had a damp rag and put on top of coil when temp feels a little hot. Could it be the coil and igniter (ICM)?
    If it's the coil, what's the best alternative to replace the coil and igniter. I checked the ICM and it's about $300 at rockauto.
    I've seen an MSD 6A (6200) + Coil Blaster 2 on an 81 Celica. Will this setup work? How hard is it to re-wire for the MSD & Coil?
    Anyone has the correct part numbers to buy for the setup.
    Thanks in advance to everyone that comments
    Jun 2009
    Melbourne, Australia
    802
    how's the weather in NJ (New Jersey?) now? you guys at in Spring? Only asking as the fuel may be vaporising.
    Check the distributor as well. I had the exact same problem on a Ford Laser once (they were sold in the US as well, no idea under what name though). Turned out that a diode or something similar inside the distributor would get hot after a few minutes of running and kill the spark. Only worked it out as a auto electrician friend had the exact same problem on the same model car a week earlier!
    Jun 2009
    Union, NJ
    58
    Yup, it's spring with about low 50's - 60's.
    I got a suggestion of doing an OHM test on the pickup-coil in the distributor. But since the pickup coil and new coil is not that much may be wise to change it.
    Thanks
    Jun 2009
    Union, NJ
    58
    It turned out to be a bad ignition coil. Runs like how it should now
  1. WTB: 71-75 Celica with 3sgte motor.
    By Socal VIP in forum Nostalgic Cars for Sale
    Last Post: 05-17-2015, 06:50 PM
  2. The Teenage Budget 1973 Celica ST- Back and running!
    By hackrtanman in forum Toyota Garage
    Last Post: 05-03-2014, 03:46 AM
  3. *** complete running 3tc motor ***
    By v8danny in forum Toyota Swap Meet
    Last Post: 02-28-2013, 05:03 AM
  4. Grandeur Motor Works 1980 Celica Convertible
    By TheDoctor in forum Toyota Garage
    Last Post: 03-03-2012, 02:39 AM
  5. Celica debating to do the motor swap
    By hawaii_620 in forum Toyota Garage
    Last Post: 06-20-2010, 08:16 AM
