Results 1 to 3 of 3
Thread: Daihatsu Charade G10
    Guest
    Hi, I'm having problems getting my Charade started - it's been garaged for about 3 years.
    I've tried jump starting it (battery flat), and I also replaced the sparkplugs (being careful to use the ones specified). The result was that the engine turned over, but didnt catch.
    There definitely seemed to be a spark, and the air filter seemed pretty clean, so am I right in thinking I probably have a fuel problem? Should I try a new fuel pump? Does anyone know where I can get parts for a '81 Charade?
    Thanks in advance,
    Richard
    Jan 2007
    3,108
    Did you add anything to the fuel tank before storing it? If not, the fuel is probably goop. You might need to drain the tank, clean it with POR-15, and then change the fuel pump and/or fuel filter.
    Good luck!
    Guest
    Thanks - i hadnt even thought about that! The car has been garaged for at least 3 years, so you're almost certainly right.
  1. Daihatsu Charade G10 facelift 1981
    By Mr_Daihatsu in forum Other Marques Garage
    Last Post: 01-25-2014, 11:36 AM
  2. Daihatsu
    By Midget in forum Introduce Yourself
    Last Post: 06-16-2011, 10:59 AM
  3. My wife's Charade G10 project
    Last Post: 09-18-2010, 08:49 PM
  4. 1974 Daihatsu 360 Max
    By kyteler in forum Other Marques Garage
    Last Post: 08-30-2010, 03:50 AM
  5. for sale: 1982 Daihatsu Charade G10 Daimatic from UK
    Last Post: 09-12-2009, 07:45 PM
