Results 1 to 7 of 7
Thread: Laurel C31 crank shaft front screw
    Jun 2010
    Germany
    8
    Hi mates!
    I need to change the timing chain of my 1984 C31 Laurels L24S engine. Therefore I have to remove the front engine cover. To undo it, I have to remove the crank shaft pulley first. It ist held by the screw that is bolted in the crank shafts front end and also holds the oil pump pinion and the timing chain sprocket.
    I think, to unscrew it I have to turn it counter clockwise. But of course, instead of undoing the screw, I turn over the engine the wrong way.
    I also have tried to put the manual transmission into first gear and block the wheels, but then it feels like the clutch is slipping.
    Does anyone have a tip, how I can undo this screw or how I can stop the engine from turning?
    Thanks awfully!
    http://data6.blog.de/media/643/5420643_ ... 97d_l.jpeg
    http://data6.blog.de/media/724/5420724_ ... 762_l.jpeg
    Jun 2010
    Germany
    8
    Hi!
    I'm still trying. I thought an impact wrench might work, but sadly i dont have one.
    So stop getting randy about showing each other pictures of show room fresh datsuns and help me.
    I don't believe nobody of you I-shoehorn-a-skyline-engine-in-my-cherry guys would know what to do!
    Thanks!
    Dec 2009
    Netherlands
    615
    if you put it in any gear and pull the handbrake it has to come off.
    maybe you have to take a n airwrench to get it off, works for me every time.
    Jun 2010
    Somewhere in the desert, NM
    199
    I'm just seeing this, but impact gun is usually the only way I've gotten those unstuck before. It may also help to spray it down with WD-40/PB Blaster/Break free (or whatever you have available where you are) several times, letting it sit for awhile inbetween sprays. Good luck!
    Aug 2009
    Los Angeles, CA
    182
    what u tryed to remove mine was any penetreating spray and impact gun and that didnt quit work so i put a torch to it to heat it up a bit and work it with the impact gun (or a braker bar with a added bar to extend the braker bar for more levrage ) and out it when .. ps dont over heat the bolt to the point wher it gets red just hot..
    Jul 2009
    New South Fails, Australia
    225
    stick it in gear, use a half inch bar with a big pole over it and pull
    Generally works
    Mar 2010
    SF Bay Area, CA
    351
    yes huge breaker bars do work well, but impact is better haha. if you dont have access to an air compressor, you can also possibly borrow/rent an electric impact gun?
  1. Ld28 V07 crank and 9mm rods
    By Jgonzo911 in forum Datsun/Nissan Swap Meet
    Last Post: 01-01-2013, 12:45 AM
  2. WTB 6MGE Crank Pulley
    By 82Supra5m in forum Toyota Swap Meet
    Last Post: 04-25-2012, 12:35 AM
  3. Need a front right fender, Laurel c32
    By gsi-power in forum Datsun/Nissan Swap Meet
    Last Post: 04-11-2012, 09:05 PM
  4. 6MGE crank pulley
    By Yotatoy in forum Toyota Swap Meet
    Last Post: 02-22-2012, 09:41 PM
  5. WTB: Looking for Enkei Screw Caps and mesh Rings
    By MonkeyMadness in forum Wheels Swap Meet
    Last Post: 01-25-2011, 05:36 AM
