Results 1 to 2 of 2
Thread: setting static timing on a L16??
    Jan 2011
    so i'm trying to set the timing with the car not running. I've got a timing light hooked up. no vac advance at this point. I'm cranking the engine by hand until the points close and I get a blip on the timing light.
    I'm not sure where to set the timing , I've got it set to 10 BDTC because that's an average spot for most cars.
    any one want to chime in with suggestions?
    Aug 2009
    Los Angeles, CA
    your about right most l sires timing is from 8 - 10 . 10 being the sweet spot . you should set it at 0 and then put it at 10 once the car is runing with out vac advance and around 800 rpm .
  1. 22R Cam timing
    By ill-minded in forum Toyota Garage
    Last Post: 11-06-2013, 02:10 PM
  2. 7MGE Fuel Pressure Regulator OE Setting?
    Last Post: 03-19-2013, 06:35 PM
  3. Timing kit datsun 510
    By Miguel SSS in forum Datsun/Nissan Garage
    Last Post: 11-09-2010, 09:11 PM
  4. help with 2.0l MA engine timing
    By rx-7fd3s in forum Mazda Garage
    Last Post: 07-02-2010, 11:37 PM
  5. The Year? 1979. The setting? Old Town Conyers....
    By qdseeker in forum General Discussion, JNC News & FAQ
    Last Post: 08-01-2009, 04:49 PM
