Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 111
Thread: 1974 Honda N600 Restoration
    Feb 2011
    Norway
    66
    Hi there. I'm a new member to this forum.
    Just managed to get hold of this 1974 Honda N600.
    I have been into Honda cars for years, but this is my first step into the nostalgic era.
    The car is sold new here in Norway, and has only 66.000 km (40.000 miles) on it, given the speedo hasn't been tampered with.
    According to the previous owner it has not been a daily driver since 1984.
    I checked with the registry and the plates was taken off the car in 1988.
    It has been sitting in a barn up till last year when the previous owner bought it as a project car. He ended up not finding time for the car due to other projects, so he put it up for sale.
    I have not been able to go through the car all that much yet, but It seems to be in good shape.
    Fuel system is clogged, and the previous owner also managed to loose a few jets in the carb in an effort to try and clean it.
    So it is a no-runner at present.
    Other than that it seems to be fairly complete.
    Interior is very good! (So I can sort of believe in the low milage)
    The exterior is a bit tired.
    Paint is extremely flat, and there is a few dings here and there.
    There has been some surface rust around the car, but this has been treated with a chemical rust sealer at some point.
    But at first impression the body appears to be quite solid.
    The plan is a full restoration.
    However it will probably take a little time before I can make some solid progress, as I'm in the process of finishing my garage, making workbenches, shelves etc. etc.
    So bear with me...
    Once this is done I will update more regularily.
    Well, enough of all this boring text...
    On with the pics:
    Feb 2010
    Cleveland, Ohio
    1,608
    Very nice project you have there! I don't believe I've ever seen a two-tone one before. It's very cute.
    Feb 2010
    Portugal
    18
    Quote Originally Posted by Camshaft
    The two tone is not original, probably a owner try to make it look like a mini cooper by painting the roof black.
    Originally the car would be all red.
    Feb 2011
    Norway
    66
    Yes, the two-tone is not original.
    Actually, the cars roof was damaged in transport on it's way from the factory, when it was brand new.
    For some reason the Honda dealership chose to put on this flat black textured paint on the roof to cover the scratches, and sold the car with a discount.
    But for sure, the two-tone is not something I'm going to keep.
    Still haven't decided on color yet, other than that is has to be one of the colors that the N600 was delivered with originally.
    Feb 2010
    Portugal
    18
    If you want i can send you a collor catalog and paint codes.
    Feb 2011
    Norway
    66
    Quote Originally Posted by franciscoasilva
    PM sent
    Feb 2011
    Norway
    66
    I kind of promised myself that I would not start fiddling with the car before I had finished sorting out the garage.
    However, my curiousity got the best of me today.
    Had to look over the car a bit to check the state of various components.
    There were some good and some bad news.
    On closer inspection the body needs a bit more attention then I first thought. To many places needs attention so it would be costing a fortune paying someone to do it. I guess I will have to learn to do a bit of sheetmetal work myself.
    The good news is that the mechanical components of brakes and suspension seem to be in great shape! I've seen 10 year old cars being in a much worse state than this, and this one is 37 years old!
    The CV-joint pic speaks for itself though.
    At least the rubber parts look their age :lol:
    OK, here goes...
    Dented roof...
    Window rubber missing from passenger door
    Right rear sidetrim damaged
    Rust holes in lower front corner of passenger door
    Rust hole in RH rear wheelarch
    Dented bumper and rusthole in aft lower part of rear RH wheelarch
    Rusthole in aft lower part of rear LH wheelarch
    Rear brakedrum
    In good shape and with plenty left on the lining of the shoes
    Some crystalized brake fluid. Plan to fit new seals
    Front struts in great shape!
    No wear to speak of on either disks nor pads.
    CV-joint not looking its best...
    Feb 2011
    North Carolina, USA
    38
    Looks great so far! :tu: Im in for more
    May 2010
    Louisville, Ky
    74
    wow thats a great find! i wanna see a video when you get it running, i love hearing these running!
    Feb 2011
    Norway
    66
    I have already started collecting a few parts.
    Buying a little here and there when I stumble across something that needs replacing.
    Had a package arriving today from "Midwest Wholesale" on ebay.
    Can highly recommend doing business with Ray.
    Very professional throughout the process.
    And note the packaging. Nice touch with the shrink-wrap plastic.
    I suspect the car has been run with an incorrect fanbelt, cause the angle on the belt into the pulley is a bit weird.
    Belt tensioner is probably adjusted way off to compensate for a too long of a belt?
    Anyway, the outer side of the pulley is badly worn, making its edge razor sharp.
    My speedo cable has a nasty kink on it, so I cant imagine this working any more.
    My engine shrouds has been molested for some reason.
    Also in the package was an oil filter, some fuel filters, a battery insulator, a gasket for the air cleaner box and the retainer for the air filter.
  1. 1971 Honda N600 restoration
    By Russell_N600 in forum Honda Garage
    Last Post: 03-28-2013, 06:58 AM
  2. 1965 Honda S600 Restoration
    By medicalstudent in forum Honda Garage
    Last Post: 12-25-2012, 08:46 PM
  3. My 1974 YamahaTY80 restoration
    By oldmaz in forum Japanese Motorcycles Garage
    Last Post: 09-26-2012, 08:07 PM
  4. 1966 Honda S600 Roadster Restoration
    By S600neek in forum Honda Garage
    Last Post: 06-30-2012, 05:33 AM
  5. My 1971 n600 restoration
    By cfio in forum Honda Garage
    Last Post: 11-23-2011, 09:05 AM
