Results 1 to 10 of 16
Thread: Putting the 280z on a diet.
    Guest
    What made the 280 weigh so much more than the 240? What can be removed to slim her down. I'd like to get to the lightest possible.
    Dec 2010
    croatia
    140
    Put lighter stuff.Maybe carbon if u rich.Remove interior and make it naked look with just basic things inside.Maybe take off mirrors,bumpers,antena,window cleaners I dont know.Just try something like that and it will be lighter
    Nov 2008
    Orange County
    248
    ...from everything I've read, the true weight difference between the 240z and 280z isn't quite apparent from what's recorded in documents from the period; differences in the way weight was measured, net and gross, and the equipment level of the cars should be taken into account, and I've heard the weights do converge more than one would think.
    Of course, the 280z is porkier. This can biol down to-
    -Thicker metal, with additional chassis reinforcement for increased stiffness.
    -Crash bars in the doors.
    -Of course, the bumpers.
    -Some extra smog gear, though due to the EFI in the 280z, there's less of this than one would think.
    -A higher level of spec on later cars compared to earlier (though mostly this boils down to more cars having AC and auto.
    ...My stock 280z doesn't feel heavy though 8)
    Dec 2009
    dallas, tx
    24
    well some points have been made, let me make some more
    Reasons why its heavier...
    crash bars
    thicker metal
    CAME undercoated from factory (that was an OPTION on early cars)
    5 speed vs 4 speed
    EFI vs CARBS (bigger tank, pump, electronics/wiring, etc)
    Smog,all that entails, plus cat/extra mufflers
    Bumpers are 15mph vs skinny 5mph
    bigger/better brakes
    bigger/better R200 setup vs early R180 rear end
    thicker driveshafts
    a/c and all that entails (rare/expensive OPTION on early cars, later cars most all had them/were added)
    ...the list could go on if we get really picky but start with what i listed and i am pretty sure you can ditch around 3-500# of stuff depending on how "light" you want to go, and how you go about it.
    Aug 2009
    delavan,WI
    99
    Yeah it would take quite a bit to get the 280z to 240z weight. Alot was of it was really to improve safety and more rigid body. Also I believe 240z has no sway bars. And there steering box is aluminum and have a bit better responsive feel.
    Feb 2007
    Perth Western Australia
    85
    S30's don't have steering boxes, they are rack and pinion.
    Aug 2009
    delavan,WI
    99
     he is right sorry bout that.
    Dec 2009
    dallas, tx
    24
    wow so much wrong info in this thread...if you dont know what youre talking about/the answer you probably shouldnt talk/give wrong info.
    240z has no rear swaybar....alot of people add this as it helps the car handle
    the 280zs have thicker metal and arent as rusty/wont get that way as easy as 240s based on that alone
    best as i can see pancho you dont own an s30 240z or 280z so what knowledge are you going off of?
    I have started a good list for you and i know FIRSTHAND that a 280z can be just as light or lighter than a 240z without swapping panels for glass/cf...its called cleaning up the car and dropping the obvious weight again i wish the OP would explain a "goal weight" and his goals for the car because obviously if he wants to drive it often and have a full interior/ac/heat/etc then you cant save the weight there.
    But again for the difference in taillights and turn signals the PRO's from the 280 -rear swaybar, R200vsR180, 4vs5spd, etc why the hell would you want an early car just to have to do all of that work lol makes no sense to me.
    shoot me a pm or email and i can help you out with anything 280z related, parts, info, and tips/tricks to get more out of it.
    Guest
    No goal weight or anything. My friend has a 240, and we got in an kind of argument over what was a better vehicle, the 280 or the 240. I was saying that the 280 has fuel injection and whatnot, bla bla. He said it was a heavy lug to pull.
    Basically I was looking at a couple of these z cars and noticed the curb weight on the 280 was like 500 pounds more than the 240. I was wondering why it was so much heavier.
    Dec 2009
    dallas, tx
    24
    ya'll can settle the bickering by taking a looky here....
    http://forums.hybridz.org/index.php/top ... fferences/
    Now i will say over and over 280z, why you ask, because if youre stuck on weight, by the time you ditch some extras....like ac (that some 240s might have and most 280s do have) & the huge bumpers the weight is already 150-200#s closer....now again alot of weight is gained because of parts/# of more parts, then again all the 280s parts are better.
    like the bigger dif, 5 spd, thicker pans/rails (so they dont rust out as easy), thicker driveshafts, bigger/better brakes...etc
    not to mention the 280s are easier to find, normally cheaper, and after you ditch the weight are about the same in any race, then again if you want to put efi on a 240 you have to swap everything, whereas adding carbs on the 280 is alot easier and alot less time....and you end up with the bigger motor =)
  1. New guy from NC with 75 280z
    By corytate in forum Introduce Yourself
    Last Post: 10-08-2012, 01:38 AM
  2. Putting my feelers out for an 18RG.
    By Camshaft in forum Toyota Swap Meet
    Last Post: 08-02-2012, 01:04 PM
  3. Putting Evo's engine in 1994 Galant GLS 2.0
    By zaidja in forum Off-Topic
    Last Post: 02-25-2012, 10:25 AM
  4. Putting on a show in upper East TN/ Western NC
    By Pooods in forum Events, Meets & Gatherings
    Last Post: 05-06-2010, 11:06 AM
  5. putting work down on the celica
    By norcalRA64 in forum Toyota Garage
    Last Post: 06-04-2009, 05:59 AM
