Results 1 to 5 of 5
Thread: SATURN (DELCO) ALT. UPGRADE INSTALL QUESTIONS???
    Feb 2008
    Saratoga N.Y.
    732
    Guest
    cut everything from the external reg off. there should be a yellow wire w/ a fusable like and a black w/ yellow stripe wire. the yellow is charge and the black is ignition. none of the 3 prong shit is worth a damn anymore. just run your hot lead off the alt to the bat and an xtra off the small bolt to the bat also as a back up your charge light will always be on from now on cause the alt will be so under worked, until you try to jump another car then it goes off cause its working at load
    Feb 2008
    Saratoga N.Y.
    732
    OK thanks for the info will try the hookup again today.
    Whit N.Y.
    Feb 2008
    Saratoga N.Y.
    732
    OK i hooked up to the ignition wire black with yellow stripe.
    ran it for 10 minutes then n oticed the alt. was to hot to touch .So just shut it down.
    also the idle was going up and down??
    Guest
    pm me your email, i will send you the wiring diagrams. send me some pics of how its hooked up and i can trouble shoot it. it took me 3 weeks of staring at the alt and wiring diagram to get it right but now it works great. we will get this puppy worked out
  1. 626 brake upgrade help
    By Oven1111 in forum Mazda Garage
    Last Post: 01-20-2013, 11:41 AM
  2. Alternator upgrade?!
    By 12345 in forum Toyota Garage
    Last Post: 06-05-2011, 11:00 AM
  3. Fuse Panel Upgrade
    By illvin_toyota in forum Honda Garage
    Last Post: 10-27-2010, 02:38 AM
  4. Replies: 0
    Last Post: 08-26-2010, 09:56 PM
  5. next upgrade to the 1200
    By moisabamf in forum General Discussion, JNC News & FAQ
    Last Post: 02-04-2010, 02:52 AM
