Results 1 to 3 of 3
Thread: got the 78 rolla started.
    May 2009
    torrance california
    28
    ok, cleaned out inside of dizzy added octane booster and starter fluid to carb, checked the spark plugs and the tips are black, but it fired up. idles REAL ruff, e.i. chugga chugga chugga... blows no smoke, but throws spatters of oil out the exhaust pipe. i adjusted the idle screw and the A/F screw and got it to not run so rich, but im assuming the oil spatters are from the rings being done for? im trying to get this to the point where i can drive it to the next JNC meet at the torrance cross roads here in so cal! ill post some pics as soon as i get a camera to use.
    Feb 2009
    FL's east coast
    98
    Carburator probably needs rebuilding. You could get a kit for it or if your really cheap (like me) just clean it out real good and you'll probably end up having to make some of the gaskets that would have come with the kit.
    One you have the carb cleaned if it still runs rough I would try leaning it out a little, sounds like its running rich if it's blackening plugs and sputtering.
    Oh, one more thing make sure it's got spark on all the cylinders it could be running on just 3. That would make it run really bad and make almost no power.
    Good luck! :tu:
    May 2009
    torrance california
    28
    thank you so much! i have leaned it slightly and one spark plug wire broke and i kind of rigged it togather so it may be running like a lawnmower for a reason! this forums great because its so fresh there are really no flame wars yet.
  1. Replies: 1
    Last Post: 12-05-2014, 01:48 AM
  2. A hello and how it all started.
    By te51 in forum Introduce Yourself
    Last Post: 05-05-2013, 07:13 PM
  3. JNC group started on Flickr! Lets add our pics !
    By bochorongo in forum General Discussion, JNC News & FAQ
    Last Post: 07-06-2011, 06:40 PM
  4. 7.4 sec AE86 rolla
    By ae86driftmaster in forum Toyota Garage
    Last Post: 06-24-2010, 12:33 PM
  5. Decided to get started on the interior...
    By qdseeker in forum Honda Garage
    Last Post: 06-14-2009, 04:58 PM
