Results 1 to 7 of 7
Thread: Carb cleaning/polishing? Has anyone done it?
    Feb 2010
    Ohio
    41
    I am about to do a MILD rebuild on my weber DCOE for my Civic and in my searches and in my weber books there are all these shots of beautiful shiny webers. Now, mine isn't dirty, but it certainly isnt shiny. I have some basic tools, including a dremel.....has anyone here polished a carb? How did you go about it?
    The air cleaner is polished as is the valve cover (but I took it somewhere to get it done)
    Id like to make this look nice if possible...any tips would be great!
    Jun 2009
    Carolina, PuertoRico
    143
    I heavent seen any polished carbs, wouldnt waste time with that In my opinion(as the filter goes over it and its practically not seen).Ive seen some carbs that look pretty well painted.
    May 2009
    Melbourne Australia
    278
    I think the way to do it is to have it bead blasted.
    Jun 2009
    Melbourne, Australia
    802
    certain parts may have been chromed or given a zinc coating.
    mind you, I cleaned my wheel caps with some kitten number 2 and a dremel buffing pad. the number 2 has a cutting substance in it, cleaned them right up, then I polished them with a fresh buffing pad and some car polish.
    before:
    after:
    Mar 2010
    Adelaide, SA
    77
    Soda blasting brings cast alloy up really well. Im currently doing a carby resto and im looking into an acid that is used to clean truck and boat alloy parts, its supposed to bring them up like new.
    Nov 2007
    Dortmund, Germany
    35
    Please do NOT polish the carbs from that point where the fuel is purified (so basically from the butterflys to the engine intake). You can smooth the walls, but not polish it as the air/fuel mixture would get back to fuel drops at the wall when they are polished.
    Cheers,
    Daniel
    Jun 2009
    802
    ^ what he said. I meant more on the outside. You want the inside to be roughly like a golf ball surface
    (or shark skin).
  1. DCOE Carb help? - Carb bogging down at acceleration
    By avianman in forum General Discussion, JNC News & FAQ
    Last Post: 04-09-2011, 06:53 PM
  2. Cleaning Datsun L20b
    By Topher88 in forum Resto Tips, Wheels & Other Goodies
    Last Post: 03-13-2011, 01:27 AM
  3. shop cleaning up
    By boxerpicker in forum Toyota Swap Meet
    Last Post: 03-11-2011, 03:56 PM
  4. shop cleaning up
    By boxerpicker in forum Wheels Swap Meet
    Last Post: 02-13-2011, 06:12 AM
  5. cleaning/polishing Mazda RX-4 wheel centre caps
    By ewokracing in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-23-2010, 11:28 AM
