Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: junkyard 510 build
    Jan 2011
    norcal
    32
    junkyard 510 build
    I'm just going to document the build here in this thread. not sure what speed this thread will grow, but i'm just gonna do it one post at a time.
    the car had been sitting abandoned on an old military base for over 10 years. moderate rust. minor dents. no motor. 79 five speed from a 210 i think.
    found the car at one of the local wrecking yards. they had already sold the 2.0 out of it and the car was mostly complete . it had only been there for 2 days and hadn't been picked over. all the trim was intact and window rubber is decent
    jan 25-28.
    towed the car home and promptly built a car dolly. pulled out the trans. pulled everything out of the engine bay and pressure washed the hell out of it. ordered a bunch of rust fighting stuff from eastwood.
    Jan 2011
    norcal
    32
    santa clawz came early (or a month late).
    went and picked up a few used goodies from my friend who's had about 7 scca 510 ITC cars.
    here's the score:
    front valance
    2 unrusted undented 68/69 fenders with turns and emblems.
    front spindles with old ground control sleeves and eibach springs with DPR camber adjusters (need to order the top portion of the plates)
    some mystery rear lowering/high rate springs
    pair of used carrera shocks for the rear
    a rear subframe modified for the race cars to allow toe and camber adjustment
    starter motor
    webber 40dcoe side draft + manifold
    4 -1 header
    1.8 head
    new fuel pump
    misc stock carb + mani
    misc brackets and linkages
    and, to top it all off,
    a balanced, blueprinted, windage tray'd, crankscraper'd , rebello built 1.6 ITC engine with race clutch from a wrecked track car!
    I'm gonna have a busy month =)))))
    Mar 2008
    Fremont, CA
    14
    Nice find!!!
    Looks clean
    Sep 2009
    Los Angeles
    161
    Interesting:
    1. I would have never thought to build a dolly out of 4 X 4s and
    2. I thought junk yards could not sell whole cars?
    Jan 2011
    norcal
    32
    Quote Originally Posted by Stevester
    Interesting:
    the vertical load is carried by 4 x 6's. there are metal plates on top to prevent the wood from splitting.
    the 2x4's are all linked to the 4x6 with 4 through-bolts each to stop the tendency to skew , and the 4x6 is also side-braced by another layer of 2x4 to prevent any torque caused by the offset of the caster.
    each caster is rated for 900lbs. the dolly is solid as fuck.
    junkyards can sell you complete cars. most places don't want to deal with the paper work, and they can make more money on parts. the independent place i go to knows me from ten years of picking parts, so he has no problem selling me a car and transferring the paperwork from the lien (as he acquired it)
    Mar 2010
    SF Bay Area, CA
    351
    Quote Originally Posted by patra_is_here
    ohhh man...droooooool
    hope to see it around norcal when you have the car running!!
    Northern California
    635
    Quote Originally Posted by Nismopunch
    I agree :tu:
    Jan 2011
    norcal
    32
    for sure. I'm now in the monterey bay. I've taken my starion to a couple of the JNC meets. I guess once this is together I'll have to do double duty. =)
    Feb 2007
    Napa Ca
    209
    If you are in Monterey, you should come out to the NORCAL UFO autoXs at Marina airport. We have 4 regular running 510s, a couple of Zs, my roadster and then the various drifters in their 240sxs. A Starion would be cool to see out there.
    By the way, NOR Cal UFO = NorCal United 510 Owners club 8)
    Will
    Jan 2011
    norcal
    32
    i've been meaning to go out and check out the autox. it's been a couple years.
  1. 6 nostalgics in Ga junkyard
    By BorinquenRotary in forum Junkyard Finds
    Last Post: 09-02-2012, 02:20 PM
  2. A day at the junkyard
    By KC30 in forum Junkyard Finds
    Last Post: 09-18-2011, 01:03 PM
  3. My Junkyard finds…
    By a_fc3s in forum Junkyard Finds
    Last Post: 11-20-2010, 12:09 PM
  4. JNC Junkyard Crawl
    By ben in forum Events, Meets & Gatherings
    Last Post: 12-27-2009, 07:22 AM
  5. A day at the junkyard
    By KC30 in forum Datsun/Nissan Garage
    Last Post: 12-31-1969, 11:00 PM
