Results 1 to 5 of 5
Thread: small diameter twin exhaust tips (rear mufflers). Where?
    Jun 2009
    Melbourne, Australia
    802
    So a lot of older "retro" cars from the 60's and 70's had a rear muffler with small (ie around 2inches or smaller) twin chrome exhaust tips.
    ie this:
    I want something for the back of my Rover, I was looking for the same thing for my Mazda wagon and got lumped with modern boofy looking tips that are too large.
    Is there a supplier out there other than Peco that does small twin exhaust tips on a muffler? This is the kind of look I'm going for:
    Though on my car, I need the tips to angle slightly towards the side of the car and then angle down (ie so the exhaust is blowing down onto the ground, rather than into the air behind it)
    I'll put some pictures up in a moment.
    Jun 2009
    802
    found what I'm after - kinda. From rubber soul of all places
    Mar 2007
    Pac NW
    500
    Not sure how much you want to do...
    Maremont makes exhaust systems, they are kinda like Walker. If you download their pdf catalog, you can look at ALL of their designs styles, with full dimensions, and then order exactly what you want
    here is the 2011 Maremont catalog - http://www.imcoweb.com/am_cms_media/dow ... =S9045.pdf
    Jul 2007
    Midwest, USA
    285
    It's difficult to figure out exactly what your goal is. Do you want an exact copy of the original? More performance oriented? Long lasting?
    The forum/website leans toward restoring for long term enjoyment and spending a little extra for long term durability. If that is the direction you are going, you might want to look for stainless, heavy walls, and lap welded muffler bodies. The alternative to avoid would be thin wall, rolled edges, and black painted finish over bare steel.
    If you are looking to enhance performance, straight through mufflers would be the way to go. But, not as common or in as wide a variety below 2 1/2 inch (despite 20+ years of the back pressure/small pipe size is better myth).
    Dual inlet and dual outlet is even more rare, and a lot are cross flow on the inside.
    No matter what the direction, your best result is going to involve welding together something from muffler, pipe, and tips sourced separately. It's not overly likely to find something pre-made.
    I've been resorting to cutting and welding mufflers to shorten or increase the height to fit into areas that no one seems to make the right size muffler for. My best suggestion for the narrow dual in and dual out would be to Siamese two 4 inch round mufflers together, but it would look like a figure 8 from the end.
    Jun 2009
    802
    Quote Originally Posted by JT191
    originality - no. The car's got a 3.5 litre V8 but it's a low comp motor and they were built for cruising, not balls out performance. It's got a replacement system on it, looks to be around 3 or 4 inch pipe with a Genie Turbo (Aussie brand) muffler in the middle with a small no name muffler at the rear.
    Basically I want to either ditch the muffler at the rear and get one with twin exit tips or add dual tips.
    However - I think that the rear muffler is restrictive as for a V8, it's extremely quiet inside and it may be overly restrictive. That's why I'm kinda leaning towards a high quality high flowing rear muffler on the back while getting the tips right.
    Basically I need something like this, but in a tube muffler, not oval:
    the tips would also have to be a bit longer and of course, a larger intake diameter on the intake pipe.
    I'm being fussy, only because the current rear setup looks fugly.
  1. twin pipes over the rear bumper
    By papo-corona in forum Resto Tips, Wheels & Other Goodies
    Last Post: 10-25-2012, 12:12 AM
  2. WTB: Mazda 12A twin dizzy early style exhaust gaskets.
    By rotary_coupe in forum Mazda Swap Meet
    Last Post: 08-06-2012, 11:56 PM
  3. TE31: small electrial issue, anyone have tips?
    By dennass69 in forum Toyota Garage
    Last Post: 03-29-2011, 04:02 PM
  4. toyota crown rear exhaust for sale NEW
    By honda-ronny in forum Toyota Swap Meet
    Last Post: 12-14-2010, 04:22 AM
  5. AE86 Rear Suspension on TE27? small bumper te27
    By skott_cha in forum Toyota Garage
    Last Post: 10-22-2010, 01:57 AM
