Page 1 of 10 123 ... LastLast
Results 1 to 10 of 95
Thread: 72 Skyline build thread
    Dec 2008
    Nor Cal
    69
    As I stated in my other tread I've been off the list for a year or so and lost my build tread. So I'll start a new one. I'm not much of a writer and spelling is a weak point so be nice. The running joke is, I only want to do things twice or maybe three times before I get it right.
    I got my car 3-31-06 a 72 GTX Skyline ( GTR Clone ) which included Rear flares, a GTR grill, front spoiler, rear wing and clear white front glass. The car came without a motor so the seller included a Nissan reman 810 engine and what he thought was a correct oil pan. After a week or so of searching I found an oil pan from another Skyline owner which was the beginning of many set backs. I then purchased a complete engine, transmission package which included triple Mukiniís, header, 5spd and misc parts. Thank goodness I just couldnít see S Uís on my Skyline. After a year plus of owning the car, it was running and driving. The first thing that had to change was the tires and suspension they were absolutely horrible. Tires where the easy part a cheap set of 195/50/14 for the fronts and I left the rears alone a pair of 245/60/14 Euro T/A s.
    I started to research the suspension for the car. My first thought was to use Z 32 front and rear brakes which lead me to M 30 front struts that would than need bump steer / adaptors from the steering knuckles to the bottom of the strut. With all that the wheel off set didnít like that setup so like I said I like to do things at least twice setup # 2 Brembo all the way around Custom hats, rotors and caliper adaptors for both front and rear you canít go wrong with a brembo setup RIGHT. Like any other 38year old car from the home land it has issues, and I will hopefully get to all of them and share them with all of you.
    Iím just an average guy that has fun working on my toys. I would never mean to offend any of you so if there is a better way or my wording is off let me know off line.
    Dec 2008
    Nor Cal
    69
    oil pan
    Here is a pic of the nice oil pan that I got
    Dec 2008
    Nor Cal
    69
    First set of brakes
    Here is the first set of brakes Z32 front and rears. M30 strut with Z 32 calipers & rotor
    M30 strut with a coil over kit
    Rear with Z 32 caliper & rotor notice caliper set at the 12 oclock position not a good idea.
    Rear caliper adaptor for Z 32
    Dec 2008
    Nor Cal
    69
    Cleaning things up
    Here are a few pic of a the bits before and after the powder coater.
    Here is a pic of the new t/c rods z32 rear caliper adaptors and strut to knuckle / bump steer adaptors. ( v6 200sx or m30 struts)
    Dec 2008
    Nor Cal
    69
    Brembo brake setup
    Here are a few pics of the do it twice brake brake setup.
    Front hats and caliper mounts for the Brembo setup.
    mockup
    280zx front struts with coilover setup, front rotors to left. If you look at the left strut you can see the new bearing / spring purch that uses a stock 280zx thrust bearing.
    Tein 510 / 240sx camber plates
    For some reason I don't have a pic of the top piece of the setup to tie it all in you you guys.
    Dec 2008
    Nor Cal
    69
    Rear brake setup
    here are my first brake caliper adaptors the top been a 810 I think for the skyline the bottom is the Z32 and the blue one is for the brembo setup with a Willwood parking setup
    This is old news now but I'm having the brembo caliper adaptors remade because they where made for a 510 and will not fit a Skyline because the bearing & bolt spacing is larger.
    Rear hub and rotors
    So if any one wants caliper adaptors I have 3 pairs I'm just kicking around.
    Jul 2007
    Sydney, Australia
    1,653
    Nice work!
    And wow that sump's pretty trashed
    Jan 2011
    norcal
    32
    Re: First set of brakes
    Quote Originally Posted by kgc10
    just wondering, what's the down side of having the caliper up there like that?
    Jul 2007
    Sydney, Australia
    1,653
    At a guess...'might be slightly harder to bleed the air out of the brake fluid if the bleed nipple isn't the highest point on the caliper
    Dec 2008
    Nor Cal
    69
    Fixed calipers should be installed at 9 or 3. Every bit you move away from that increases knockback.
  1. best Skyline R30/R31 thread
    By szymonsta in forum Datsun/Nissan Garage
    Last Post: 05-05-2015, 11:48 PM
  2. Cam's Mazda2 Build Thread
    By Camshaft in forum Off-Topic
    Last Post: 12-06-2013, 11:29 AM
  3. Tim's '72 hakosuka build/buy thread (YAY!) lol
    Last Post: 08-08-2012, 03:08 PM
  4. RA43 Build thread.......
    By RA43power in forum Toyota Garage
    Last Post: 08-07-2012, 01:45 AM
  5. NZ HR30 Skyline RB30DET build thread
    By rb30det-r30 in forum Datsun/Nissan Garage
    Last Post: 09-27-2010, 02:06 AM
