Results 1 to 10 of 15
Thread: Fender mirror installation help...
    Atlanta, GA
    213
    I just received a set of mirrors for the fenders of my car and am not too sure of how to mount them. It looks to have a guide screw, but the thing that throws me off is this set has the spring that comes down off the base and the base is a silver/metal rectangular piece that, I assume all goes on the inside of the fender.
    Could someone please help me out with some sort of step-by-step with install?
    Thank you in advance!
    5,530
    Yes, all that goes inside the fender. Take it all off, drill the mounting holes through the fender, snake that long stud through, then reassemble it all inside the fender. That silver metal plate rides up against the bottom of the fender (on the inside).
    The spring is there so that if someone walks by and accidentally bumps the mirror they won't break it off. :wink:
    5,530
    Also, if there's a plastic/rubber "gasket" at the base of the mirror itself, obviously that goes between the mirror and the fender, not underneath. :tu:
    Atlanta, GA
    213
    I guess it'd be easier to do with the fender off, yes?
    Dec 2008
    Malaysia
    320
    Quote Originally Posted by qdseeker
    Maybe, depending on car, how tight is the room under the fender.
    I've never had to remove a fender to install one, yet.
    5,530
    Easier, yes. But when you add up the hassle of removing the fender plus the mirror install, compared to just the hassle of the mirror install with the fenders on...
    I usually keep them on. 8)
    5,530
    And if these are going on the Civic, what are you going to do with the Napolean/Phantom mirrors you're taking off? 8)
    Atlanta, GA
    213
    ^^^ I'm sure I'll get rid of them, sir....
    The only problem I encounter with leaving the fenders on is the wheel well gets in the way of moving about. I'll check out in a few, though.
    Dec 2009
    Netherlands
    615
    take off your wheel first..
    if you decide to take off the fender, keep in mind you measure were to drill the holes with the fenders still on the car.
    Atlanta, GA
    213
    Quote Originally Posted by Eric
    This is exactly what I did. This enabled me to NOT have to remove the fender after all.
  1. Fender Mirror Question
    By nihon in forum Toyota Garage
    Last Post: 10-16-2012, 02:31 AM
  2. wtb fender mirror
    By savannarx7 in forum Mazda Swap Meet
    Last Post: 09-02-2012, 10:59 PM
  3. WTB. Fender Chrome mirror
    By pakundo in forum Wheels Swap Meet
    Last Post: 05-28-2012, 12:45 PM
  4. fender mirror placement.
    By jdmeg21 in forum Toyota Garage
    Last Post: 03-05-2012, 09:15 PM
  5. Name this Fender Mirror
    By gripswingmx32 in forum General Discussion, JNC News & FAQ
    Last Post: 02-20-2012, 05:01 PM
