Results 1 to 3 of 3
Thread: fuel injection
    fuel injection
    Anybody ever fuel injected an N600? :wink:
    Jan 2009
    Olympia, WA
    Not that I've ever seen, but it shoudln't be too hard to do with a single throttle body adapted to fit the stock carb manifold. Or if you actually have two intake ports, one throttle body per cylinder, with a custom manifold. That would be pretty sweet! You could drive it with MegaSquirt, and maybe add a little boost to the stock motor!!! You might be able to get 50-60hp out of one of those little guys! Something like an Extrudabody throttle body would probably be the easiest to adapt.
    I know there was a performance kit sold back in the day for these cars. High compression pistons, and a header and I think they were able to bump the car from 36 to 45hp. I guess it would outrun the Minis of the day. Not sure if they were talking the 850(?) minis or the 1275s. The 1275s were quick, so I think it would be a stretch.
    Heard rumor of certain Goldwing pistons fitting in there too, other than that haven't heard or seen much else on modifying those motors.
    Feb 2007
    Baltimore, MD
    Yea it would be fairly easy with MegaSquirt. Perhaps look for manifolds/throttlebody off a single cyl. fuel injected bike. A duel manifold wouldn't help because of the way the head is constructed. Its a single port that spits into two inside the head. You could put on the "Hawaiian" head which has two separate intake ports, I hear its a great mod for these little engines.
  2. [AUS] IDA fuel injection conversion
    By koka90 in forum Mazda Swap Meet
    Last Post: 06-19-2014, 08:43 AM
  3. Fuel filling issue from Gas station fuel nozzles
    By RT119Patrick in forum Toyota Garage
    Last Post: 02-14-2014, 05:13 AM
  4. L 20 B Fuel Injection ?
    By down n dirty in forum Datsun/Nissan Garage
    Last Post: 11-25-2012, 09:31 PM
  5. Searching for OEM part - air injection control valve
    By jraesly83_rx7 in forum Mazda Garage
    Last Post: 03-22-2012, 12:24 AM
