Results 1 to 10 of 10
Thread: Semi-nostalgic Datsun/Nissan 50th AE Z31
    Sep 2009
    Ashland, VA
    6
    I finally found a car I really want to keep...in the form of my 50th AE Z31.
    Some info on the 50th AE:
    5,464 Special edition Anniversary Edition Z31s were built as 1984 Models, which featured a Two-tone paint job, flared fenders, side skirts, mirrored t-tops, bodysonic bass-in-seat stereo system, an AE badge on the driver's side fender.
    The car also came with a golden key and a 50th AE cover, neither of which I have.
    It originally had a VG30ET making 200 HP @ 5200 rpm and 227 ft. lbs of torque @ 3600 rpm, but the previous owner removed the badly mangled motor and replaced it with a higher compression NA VG30E with the turbo goodies bolted on.
    Proper pics:
    It currently has spray painted front fenders and bumper cover until I can find decent original AE replacements.
    The car is leaky, which is what I'm working on this winter...trying to keep the fluids where they belong. It leaks gas, oil, coolant, brake fluid and has a boost leak and intake leak.
    Once I get this all wrapped up, I am going to install a boost gauge and turn the boost up to 10 psi, which is about the most a stock clutch can take.
    It's currently set at 8 psi, which is only 1.3 psi more than stock but runs pretty well and pulls pretty hard.
    All-in-all, it's a fixer-upper, but a piece of Nissan history and I adore it.
    Apr 2010
    snohomish, washington
    497
    Nice dude I'm thinking of picking up a z31 for a drift car but mine would be completely different and powered by a small ka24e turbo engine.
    Feb 2010
    Cleveland, Ohio
    1,608
    I love these 10th AE cars. :tu: I hope you keep us updated on the restoration process, I want to see this thing returned to it's '80s techno-packed goodness.
    5,527
    Quote Originally Posted by Camshaft
    FYI, it's a 50th AE. :tu:
    Feb 2010
    Cleveland, Ohio
    1,608
    OMG, n00b mistake, sorry. Was looking at 10th AE FCs in my other tab. Like these Z31s better, though. :wink:
    Dec 2007
    Ohio
    354
    Nice z31 you have there. Keep us updated on the progress of it.
    Sep 2009
    Ashland, VA
    6
    Thanks for the kind words.
    Will-do.
    I have the original front fenders, but they're rough. I'll probably put them back on before spring though and try to fix the rust on them.
    It will be many years before I can afford to paint it the way that I want to and afford to purchase the decals.
    Apr 2009
    Central Fl
    196
    I love the Z31 nice...... Also does your cluster still work right???
    Sep 2009
    Ashland, VA
    6
    Yep. Dash works, but I have no gas reading since my fuel level sending unit is kaputt.
    New South Wales, Australia
    692
    Damn that's cool!
    Do want. You're a lucky man.
  1. Does this count as nostalgic? 1989 Nissan Micra
    By Dave77 in forum Datsun/Nissan Garage
    Last Post: 01-17-2012, 09:07 PM
  2. Semi new Tiara owner.
    By Drive510 in forum Introduce Yourself
    Last Post: 05-19-2011, 05:20 AM
  3. Re: 1983 Nissan Skyline RS-X Turbo (50th Ann. Ed.) $28k
    By JNC in forum Ad / Auction Finds
    Last Post: 11-07-2010, 10:50 PM
  4. Nostalgic Nissan Feature on Yahoo Auctions...
    By Kuroneko in forum Datsun/Nissan Garage
    Last Post: 08-29-2010, 02:20 AM
  5. Semi Pro Honda Crx Photoshoot
    By Robb in forum General Discussion, JNC News & FAQ
    Last Post: 08-29-2009, 01:36 PM
