Results 1 to 10 of 11
Thread: Carburated Turbo?
    May 2009
    South carolina
    14
    Carburated Turbo?
    hello to all! I got a question regarding carbuarted turbo's. I have a 82 corolla wagon and I want to Turbo it, but I'm trying to keep cost down. I already have the main ingridients for it (turbo,manifold, upgraded ignition system, aftermarket Mikumi carburator, tubing and intercooler) my question is do I have to upgrade my carb? do they sell carb bonnets for these mikumi carbs? and how much boost can this carb handle? Thanks for the help. Be safe and God Bless the Marines
    5,527
    Re: Carburated Turbo?
    Quote Originally Posted by jfgfmly
    Mikuni made like 1400 different carbs over the years. Can you narrow it down a bit? :P
    Unless it's been properly pressure sealed, none.
    Oct 2008
    trussville, al USA
    21
    get rid of the mikunis and get a holley and do like they do in south america. i know they make sealed covers to run turbos for the holley carb not to mention with the right engine setup and carb tune you could run somewhere around 25 psi with it. if you need more info ask some of the guys in the toyota boards. :mrgreen:
    May 2009
    South carolina
    14
    Holley Carb
    I been told several times to go with Holley carbs. I'm going to look into it. Thanks
    May 2009
    South carolina
    14
    CFM's?
    Im tryin to run 12-18 psi max. How many CFM's should the Carb be?
    Oct 2008
    trussville, al USA
    21
    my guess would be to go with a 750-850 cfm carb should make good power. just make sure to put it on the dyno and tune the jets on it so you dont run it too rich or too lean at WOT
    May 2009
    South carolina
    14
    Thanks, I already got my boy working on the carb bonnet. I will post pics soon.
    May 2009
    South carolina
    14
    Did I miss anything? all I/m looking for is 300 WHP
    5,527
    You should be able to do that easily. Of course it may only last a few minutes...
    Jun 2009
    Palmdale
    34
    TURBO CARB, 22R WITH 20 HEAD
    carbs can handle boost.. I boosted 24 lbs on 44mm Mikunis.. As far as the Preasuse box for the carbs....? I had one custom made, it was cheaper.. but you can buy the one they sell for the vw carb turbo kit.. good luck..
  1. WTB HKS 5MG/6MG Turbo kit.
    By CoKaidoSquad in forum Toyota Swap Meet
    Last Post: 07-31-2013, 01:33 PM
  2. Z31 Turbo
    By Alvin in forum Datsun/Nissan Garage
    Last Post: 11-17-2011, 02:59 PM
  3. HKS 4k Turbo kit.
    By 1978 ke30 in forum Toyota Swap Meet
    Last Post: 11-10-2011, 02:26 AM
  4. Replies: 1
    Last Post: 11-06-2010, 03:40 AM
  5. My S5 FC Turbo
    By in forum Mazda Garage
    Last Post: 10-15-2009, 05:01 AM
