Results 1 to 6 of 6
Thread: Carb Questions
    Nov 2008
    utah
    178
    Carb Questions
    Ok, so i am going to hold out on swapping my car to a RB, so it means i need a little more power to hold me over. I am going to do a L28 in my car, but dont know what carbs to do. DO the SU's off the 240 and 260 work for the L28 or does the extra displacement hurt the performance? Also from your experience would you do stock style SU's or Webers, those are the 2 different ones i am really thinking about. I want something that isnt to much hassle as i change altitude alot living in the mountains, as well as pretty drastic temp changes.
    Sorry if i stole anyones pictures by the way. They just do a good job of showing the 2.
    5,529
    Re: Carb Questions
    Quote Originally Posted by skyrine
    If you have a stock cam and aren't planning to rev it over 5k much, I'm sure they'll be fine. Should be nice and torque-y. :tu:
    Then why not EFI? Simple, cheap, and does everything you need?
    Not quite as "sexy" though... :P
    Jul 2007
    Sydney, Australia
    1,653
    As a third alternative, I think Ztherapy offer enlarged SU-style carbs, so you can keep the stock look, but will be an upgrade from the twin Hitachis, that will almost be as powerful as triples, but less finicky
    Feb 2007
    Napa Ca
    209
    SUs will not like really big cams. They can be made to work, but it might not idle well. Webers are tough to jet since they have more adjustments than you can shake a stick at. Mikunis can also be tough to jet, however you have less things to play with to get them to run well. I'd say you want 44/45mm carbs, with likely 37mm venturis depending on the head work done and the cam you are running. From what I have found the Mikunis don't seem to be affected by weather or small changes in altitude much. (Small as in 1500 feet or so.) The last time I ran my car at altitude, I went a step smaller in the fuel jets, but I was also at nearly 7000 feet when jetted for sea level.
    Remember, if you improve things on the intake side, you need to improve things on the exhaust side as well.
    Will
    Nov 2008
    utah
    178
    Forgive my ignorance but what do you mean on the exhaust side? I am already running a tubular header to a 2.5 straight pipe all the way out. I hope you are not telling me i need to do machine work to get a decent performance out of the 2.8 as i am mainly doing it to hold me over until a RB swap in a couple years.
    Feb 2007
    Napa Ca
    209
    I missed the fact that you already had headers and a large exhaust. I'd say you are good on the exhaust side.
    If you spent the $$$$ for a well built head, you could have lots of hp if its done right.
    Will
  1. some questions..
    By liquid51 in forum Honda Garage
    Last Post: 02-17-2013, 09:24 PM
  2. WTB: 4m or 5m carb'ed intake manifold and carb!!!!!!!!!
    By just_a_supra in forum Toyota Swap Meet
    Last Post: 01-12-2012, 01:50 PM
  3. RX7 GSL-SE Questions.
    By in forum Mazda Garage
    Last Post: 09-05-2011, 02:47 PM
  4. DCOE Carb help? - Carb bogging down at acceleration
    By avianman in forum General Discussion, JNC News & FAQ
    Last Post: 04-09-2011, 06:53 PM
  5. a few 3tc questions
    Last Post: 04-14-2010, 07:03 PM
