Results 1 to 10 of 17
Thread: Oil cooler...
    Atlanta, GA
    213
    Oil cooler...
    I've been wanting to put an oil cooler on my Civic for a while now. Is there a certain number of rows I should look at or does it really not matter?
    Thanks.
    5,530
    Unless you are regularly tracking the car, no it does not matter.
    Inside or outside? Either may limit the size of it a bit.
    Atlanta, GA
    213
    It will be inside mounted. Where the AC condenser used to be. I'm going for a more stock look than Boso. It isn't for track, but my mechanic told me that the engine I have in there will benefit (longer lasting) if I do utilize one. This engine already has the leads for one, too.
    Jul 2007
    Midwest, USA
    285
    I would suggest against the style of cooler that are a single pipe that turns back and forth threading through a rectangle of aluminum fins. These are the cheap and low quality ones that are more typical in the US.
    As a comparison for style, and an indication of quality and efficiency, look at the oil coolers that are used as original equipment on turbocharged cars. They are thick, formed with the oil plumbed through stamped fins. These get the oil closer to the metal and do a better job transferring the heat out of the oil and into the body of the cooler assembly.
    B&M make oil and transmission fluid coolers, some are called supercoolers. They all follow the same basic design, 1 1/2 inch thick, 11 inches long, and a variety of heights to match the cooling need (4-11 inches).
    Setrab make thick coolers and they have a good reputation.
    One last note. If you are dealing with an overheating problem, the solution is a bigger radiator. Better cooling and more capacity of the coolant will provide more benefit than more cooling of the lubricant. They call them water cooled engines for a reason.
    5,530
    Quote Originally Posted by JT191
    Which is why the stock RX7 oil coolers are so commonly used. :tu: :mrgreen:
    Atlanta, GA
    213
    I was wondering about the B&M ones. You're talking about something like the below?
    No overheating issues at all.
    This is why the question. I have access to one of these at no cost. This would work well?
    Jul 2007
    Midwest, USA
    285
    Quote Originally Posted by qdseeker
    â– All aluminum construction
    â– Stacked Plate design
    â– Pressure tested to 200psi
    â– Mounting brackets built into cooler
    â– New 3/8” diameter nipple fittings
    â– Automatic transmission coolers include mounting kit
    1. High technology design includes the ‘Low Pressure
    Drop’ feature to reduce the risk of lube system failure.
    2. Fluxless, oven brazed construction is vibration resistant.
    3. Multiple oil flow paths for maximum cooling efficiency.
    4. Revolutionary ‘stacked-plate’ construction
    5. Lightweight aluminum alloy for maximum corrosion resistance.
    They seem to be less expensive and easier to find than the Setrab coolers. But I don't like the mounting brackets though, they are flat out to the sides and would block airflow if you mounted the cooler in front of a radiator.
    5,530
    Yes, it should work very well.
    Atlanta, GA
    213
    I'm not going to put it in front of anything. It's going to be on the radiator support NEXT TO the radiator. Where the AC condenser used to be. So it'll be right behind the actual grill.
    Right behind the CVCC part of the grill in the pic below...directly in air flow path...
    Nov 2008
    Strasburg, VA
    508
    you have no need for an oil cooler. if anything, you may actually harm your engine by the oil being too cool. oil is best at around 170-210 degrees. get an oil temp gauge, then figure out if you need a cooler or not. my guess is that you aren't anywhere near that temperature.
  1. (Boso style) RX7 Oil cooler setup (almost functional!) $100
    By hmph in forum Universal Parts Swap Meet
    Last Post: 11-07-2014, 09:01 PM
  2. For Sale: Large Oil Cooler
    By Phaze2Henry in forum Universal Parts Swap Meet
    Last Post: 05-12-2014, 07:20 PM
  3. rx7 oil cooler and benz fogs
    By skib in forum Datsun/Nissan Swap Meet
    Last Post: 10-02-2012, 03:38 AM
