Results 1 to 10 of 12
Thread: MSD Ignition
    Aug 2009
    Malaysia
    359
    MSD Ignition
    is there any clear benefits from using it?
    are they able to be used with carb cars?
    Jul 2007
    Sydney, Australia
    1,651
    Feb 2008
    scappoose, or
    754
    I dont really care for them personally. Go spend the money on some carbs or a cam instead.
    Jul 2008
    Alabang, Philippines
    46
    Quote Originally Posted by city hunter
    But once you've already spent money on your cam and carbs.. an MSD is a nice toy too
    I have a Digital 6 in my Lancer with all the goodies... high speed retard and launch control installed. :twisted:
    Hope, British Columbia, Canada
    55
    I use one just for the convenience, new technology, new wires. Gotta be better than 40 year old stuff
    Nov 2010
    Adelaide-Australia
    7
    I recently installed one into my cammed corolla, made a world of difference down low in the rpm range!
    Aug 2009
    Los Angeles, CA
    182
    Quote Originally Posted by slo-030
    slo-030 is right u do feel a diff down low and up high.. it also evens out your idle.. it will also allow u to open up your spark plug gap more. if u have carbs you will notice the diff as it will burn the fuel more and give u extra ponies and increase your mpg's ... i have msd 6a with ss coil and a gap of .50 on 77 810 datsun
    Apr 2009
    Central Fl
    196
    Plus they are waaaaaay cheaper than a ignitor for a Toyota......
    Plus u can go the cheap route and use a hei module
    Jan 2008
    Sydney Australia
    35
    hey guys,
    I have an MSD 6AL 2 with 2 step rev limit and launch control on my 2T-G with 45mm Webers. It has eliminated the miss at high revs with the standard toyota igniter and Bosch GT40 coil. I use it with a magnetic pick up from ra60/40 22r/20r motors. It hasn't missed a beat since.
    I launch at 6500rpm and final rev limit to 8800rpm.
    I recently also bought an MSD timing computer for a more linear timing advance.
    The mechanical weights for timing advance was a pain driving the car on the street. I took them out and locked the distributor:
    I also marked the crank pulley for reference on the amount of advance:
    So far the car has been a lot smoother to drive and I am able to adjust the total advance with a timing retard option on the timing computer if the advance is too high.
    MSD is a great product and I would recommend it to all, so simple to install and easy to use. You are able to retard the total timing by 4/3/2 or 1 degree if you like.
    Jul 2007
    Sydney, Australia
    1,651
    That timing computer is neat! I looked it up, and the pre-programmed advance curve should be pretty much perfect for any nostalgic
  1. Electronic Ignition conversion - 2M
    By Holmen in forum Toyota Garage
    Last Post: 07-24-2015, 10:09 PM
  2. WTB Ignition Switch for '73 Crown
    By Myron Vernis in forum Toyota Garage
    Last Post: 04-27-2015, 06:27 PM
  3. 240Z ignition problems
    By Tommy in forum Datsun/Nissan Garage
    Last Post: 08-20-2012, 02:08 PM
  4. electronic ignition
    By itsuki in forum Toyota Garage
    Last Post: 12-22-2011, 06:15 AM
  5. post your ignition setups!
    Last Post: 12-01-2011, 01:06 PM
