Results 1 to 3 of 3
Thread: Fuse Panel Upgrade
    Aug 2010
    chicago
    13
    Fuse Panel Upgrade
    The main fuse in my 82 is blown and I can not locate a new fuse that will fit the original panel. Has anybody upgraded their fuse box? If so can you post what you have used instead of the stock.
    Thanks
    Mar 2010
    New Jersey
    24
    What kind of fuse was in there? What amperage was it rated for? Did it look like a mini-wrench before it blew? If it's the same as the '79 and earlier Civics, they are still available.
    Aug 2010
    chicago
    13
    Quote Originally Posted by Jonathan
    Thanks, I found an aftermarket 50 A fusible link that will work for the main fuse. The contact plate was copper and I was able to drill my own holes to accommodate the factory fuse panel screws!
  1. WTB - AE92 Engine Harness + fuse box
    By not12listen in forum Toyota Swap Meet
    Last Post: 01-16-2013, 01:10 AM
  2. mx32 dome light fuse
    By 3ne2nr in forum Toyota Garage
    Last Post: 03-24-2012, 02:16 AM
  3. WTB MX32 header panel (Front Panel)
    By poopra87 in forum Toyota Swap Meet
    Last Post: 10-06-2011, 06:01 PM
  4. Where is the fuse box for Datsun B210?
    By Kev3 in forum Datsun/Nissan Garage
    Last Post: 08-22-2011, 01:35 PM
  5. 1969 Corona 2 door fuse block and cover. sold please delete
    By Red85Celica in forum Toyota Swap Meet
    Last Post: 11-29-2010, 12:13 AM
