Results 1 to 6 of 6
Thread: 240z Extended Wheel Studs
    Dec 2009
    Denver
    18
    Does anyone know any company's that make extended wheel studs for the 240z. Or maybe a factory stud from another car that will work that is longer?
    Thanks
    Dec 2009
    Denver
    18
    I just read that the 2nd gen rx-7 are longer and fit, or the nissan quest are about 9mm longer. Can anyone confirm that?
    5,530
    Nissan Quest used studs 10mm longer, yes. Used those many times. :tu:
    If you want really long studs, you can get 2.5" long studs from ARP (Part number 100-7708).
    Dec 2009
    Denver
    18
    Awesome, thanks for the conformation. Do you know by chance what year Quest? Thanks so much
    5,530
    Quote Originally Posted by eeffectapparel
    I usually ask for studs to suit a '96 Quest. :tu:
    Feb 2007
    Huntsville, AL
    38
    You need to get the Quest rear wheel studs. They have the correct knurl diameter (12.9mm) and are 45.5mm in length.
    The front Quest stud will not work as they have a knurl diameter of 14.3mm.
    The Nissan part number for the rear Quest stud is 43083-35F00. The aftermarket studs are much cheaper. The NAPA part number cross is 6412785 and the Dorman part number is 98363
    If you're at the boneyard then look for a first gen 1993-98 Quest Van.
    For more info check my reply at:
    http://forums.hybridz.org/index.php?showtopic=46032
  1. '72 510 and '73 240z
    By fiveONEoh in forum Datsun/Nissan Garage
    Last Post: 08-01-2013, 03:36 PM
  2. My 71 240Z
    By SLCustoms in forum Datsun/Nissan Garage
    Last Post: 04-24-2013, 09:39 PM
  3. FS: l28ET ECU's/AFM's,CAS,Degree wheel/intercooler + 240z
    By Sdgoods in forum Datsun/Nissan Swap Meet
    Last Post: 04-22-2013, 08:28 PM
  4. anyone using ARP studs for their header/intake mani?
    Last Post: 05-31-2012, 05:34 AM
  5. CSI JDM wheel center cover for 5 spoke wheel
    By bionichicken in forum Wheels Swap Meet
    Last Post: 07-07-2011, 01:41 PM
