Results 1 to 6 of 6
Thread: spacer/offset bracket for Hako front brake upgrade
    Jul 2010
    Litchfield Park ARIDzona
    382
    has anyone bought a set of these? i would like to look into having a set made for my Hako, (my dads a machinist..)
    SO i was wondering if anyone can upload a PDF with the dimensions drawn out and the design so i can look into have a few sets made??
    Northern California
    635
    Re: spacer/offset bracket for Hako front brake upgrade
    The caliper spacer is pretty common in Japan. If you read through the works mags & many others you will notice owners have upgraded to either R32 or Hilux calipers. I spent hours of research trying to find measurements or detailed photos. Found some details but until the calipers arrive I wont be able to confirm.
    A friend of mine has already made a CAD design but wants the calipers in hand so final measurements can be made. Once those are done Ill send you a copy which should be soon. Also if you want to use 15" wheels keep in mind you will need to use different front hubs to clear the calipers.
    Now If shipping from Japan wasn't so expensive and I had 38,800/JPY. Id probably just buy a set from Rubber Soul/Victory 50. But at todays horrible exchange rate. Its probably best to make your own. :lol:
    Will keep you posted.
    Jul 2010
    382
    awesome, thanks !
    so what would you change the front hubs for? i mean i understand why, but
    what hubs would you install instead? S13 maybe?
    Jul 2010
    382
    cause i dont want to have to find these parts when i get to the US with the car.. all i need is the offset bracket and i wont have to swap my struts out.. seems just as easy and cheaper to me
    Mar 2010
    SF Bay Area, CA
    351
    if you are still in Japan they should be pretty easy to get a hold of
    Jul 2010
    382
    the point is, i wont be in japan forever.. so the L bracket is super easy to try first
  1. MX32 Cressida brake upgrade option
    By Banglabhai in forum Toyota Garage
    Last Post: 05-08-2013, 08:14 PM
  2. 626 brake upgrade help
    By Oven1111 in forum Mazda Garage
    Last Post: 01-20-2013, 11:41 AM
  3. FOR SALE, rx2 brake and diff upgrade S.A.
    By wilsonbeck in forum Mazda Swap Meet
    Last Post: 08-14-2012, 03:44 AM
  4. MS63 easy brake upgrade?? 71-74 crown
    By ashms63 in forum Toyota Garage
    Last Post: 03-19-2012, 08:45 PM
  5. Brake Booster spacer???
    Last Post: 12-05-2010, 10:21 AM
