Results 1 to 9 of 9
Thread: Custom rim widening shops in Northern California
    Oct 2010
    Sacramento, CA
    15
    I'm looking for some reputable quality shops in Northern California that can widen my alloy rims from the front. Similar to this:
    http://www.youtube.com/watch?v=h6hXvqE5w8Q
    Here's a pic of the rims I want widen, they are 13x5 and I want them widen to 7 inches:
    Lets hear some input and I want to know if it's even possible to perform this task to these rims. Thanks in advance.
    Aug 2009
    Los Angeles, CA
    182
    you cant widen alloy wheels only steel wheels... i might be done but i wouldnt recommend it since alloy is porous and the weld wont be as stron as steel weld, also u will need to find a alloy piece to ad the width u want ....
    Oct 2010
    Sacramento, CA
    15
    AHHHH.. I thought so.. dang it. I'm better off finding some rims the size and design I want..
    Jul 2007
    Midwest, USA
    285
    Research only, no experience with these:
    http://www.stocktonwheel.com/wheel_widening.htm
    http://www.weldcraftwheels.com/
    http://www.vikingwheel.com/services.html
    All three widen alloy wheels.
    Also look at:
    http://www.japanesenostalgiccar.com/for ... hp?t=11771
    This thread discusses Coddingon machining a larger diameter center of a Supra wheel, and welding it into a spun aluminum rim. There is no reason that this could not be done with a cast wheel center, and no reason that a cast wheel center could not be cut out and machined to be reused as the center of a three piece wheel, with a bolt on inner and outer rim.
    Not sure how strong any of these options would be, but all are possible.
    Oct 2010
    Sacramento, CA
    15
    Thanks. I emailed Stockton Wheel before, and they emailed me back saying they only work on steel wheels. I will look into the other ones. Any Sacramento locals here that know some shops in the area?
    Oct 2009
    Monterey Park ,Ca
    119
    Finding a shop locally is not gonna happen. Very few shops do this type of work.
    Oct 2010
    Sacramento, CA
    15
    Hey rkkopra73, what kind of modification did they perform on your aluminum wheels? If it was widening, did they widen it from the back or from the front (i.e., deep dish). Thanks in advance.
    Oct 2009
    westminster
    31
    If someone would, it will cost $1000 plus. Eric Vaughn can do it.
    Sep 2009
    bolsa
    69
    mideng wheel works in stanton does it too....contact mr. ralph mideng
  1. Southern California early Z tuning shops
    By Aeropooch in forum Datsun/Nissan Garage
    Last Post: 12-01-2013, 06:38 AM
  2. Hello from Northern California
    By Ayisu in forum Introduce Yourself
    Last Post: 10-26-2011, 10:45 AM
  3. Hello! from Northern California
    By High5maxi! in forum Introduce Yourself
    Last Post: 11-23-2010, 05:09 AM
  4. Northern California Car shows?
    By Scary Scott in forum Events, Meets & Gatherings
    Last Post: 07-15-2010, 11:45 PM
  5. last min car meet today northern California
    By autobot_crx in forum Events, Meets & Gatherings
    Last Post: 06-28-2009, 09:41 PM
