Results 1 to 10 of 12
Thread: MMC 4G52 engine, carburetor Mikuni, need photo
    Apr 2008
    Belarus, Minsk
    11
    Hi!
    I'm very need photos of mikuni carburetor connected in to 4G52 engine, with all vaccum, fuel, water heat connections. My car MMC Galant Lambda A133.
    Apr 2010
    philippines
    134
    looks like you needed a manual more than just pictures, that is if those connection were out of place before your knowledge
    Dec 2007
    New Zealand
    210
    Post a pic of what youve got and we can draw arrows on it of what goes where.
    Dec 2008
    Arg
    7
    Re: MMC 4G52 engine, carburetor Mikuni, need photo
    Quote Originally Posted by skd
    Hi!
    Dec 2007
    New Zealand
    210
    Not to sure about the other side, very different to mine, a few of those probably go to the auto choke that's usually on the side.
    Oct 2010
    Russia, Novorossiysk
    26
    I have now a same problem...
    Id have to go look but from memory the rearmost thing on the minifold (with a square base) is brake booster, next is heater, little one on the botom is water to bottom of carb
    do you have the rubber adapter bit that goes on small brass fitting next to the idle mixture screw?
    the fitting on the diaphram housing is a fuel return
    the little brass one under the carb on the inside goes to rocker cover
    the others and the vac/temp switch ones are a little more difficult and you really need to grab the set from a wreckers to get all the fittings that go with the hoses ,
    edit, arrr ok maybe not where u are Il get a photo of one later on , you will need T pieces etc or can you delete things like the egr valve and other pollution gear?
    Mar 2010
    Philippines
    55
    Quote Originally Posted by Se-R
    Hi!
    Se-R,
    I've noticed the dual card. What carbs are those? I'm planning to get dual carbs for my 4g52 as well. What works best?
    Mar 2010
    Philippines
    55
    Hi!
    Hi SKD,
    Here's a picture of my Carburetor in my 4g52 engine:
    PS: It's not stock.
  1. Need help/suggestions for carburetor
    By Metatron in forum Mazda Garage
    Last Post: 05-06-2013, 02:21 AM
  2. Specs of Flywheel Bolts for 4g52 Engine?
    By burgggie99 in forum Mitsubishi Garage
    Last Post: 12-07-2011, 08:06 AM
  3. 4M carburetor question
    By jzcelica in forum Toyota Garage
    Last Post: 03-17-2011, 03:23 PM
  4. 4g63 head in a 4g52
    By dwlee in forum Mitsubishi Garage
    Last Post: 02-17-2010, 11:33 PM
  5. Hey guys,4g52 Valve timing
    By in forum Resto Tips, Wheels & Other Goodies
    Last Post: 12-13-2009, 07:16 AM
