Results 1 to 9 of 9
Thread: headlight condensation
    May 2010
    Louisville, Ky
    74
    hi everyone, i just recently picked up a first gen crx and it has water condensation inside one of the headlights. does anyone have any tips for getting the water out? i do believe the headlights are glass if that makes a difference
    5,527
    The condensation is usually because of a "leak" in the light. Only real options are to disassemble and reseal (tricky job), or buy new ones. :cry:
    Unless of course the leak is something obvious, like a crack in the housing?
    5,527
    Just to clarify, your headlights look like this, right?
    NOT like this:
    Nov 2008
    Strasburg, VA
    508
    time to get some EDM black housing lights... like this:
    check www.redpepperracing.com for some or some stock ones too.
    May 2010
    Louisville, Ky
    74
    theres no obvious crack or anything that i can find, i cant see the first image that u posted datsunfreak but i can see the second pic and those are not what my headlights look like. id rather try to fix them then buy a new set. so what exactly would it take to fix them, just disassemble the headlights and use like an epoxy or something to seal them back together? thanks for the reply's guys!
    5,527
    Quote Originally Posted by andysmiley17
    Exactly. And if they have vent tubes, make sure they aren't clogged up. :tu:
    Nov 2008
    Strasburg, VA
    508
    yeah, check the vents first. those should be clear. if they aren't that could very well be the fog issue.
    May 2010
    Louisville, Ky
    74
    hmmm never heard of vent tubes lol, im guessing they are on the back of the headlight near the headlight bulb?
    5,527
    Yeah, little rubber elbow, usually just above the bulb socket. :tu:
  1. WTB C10 Headlight covers
    By DaveW in forum Datsun/Nissan Swap Meet
    Last Post: 08-04-2014, 07:07 PM
  2. WTB 86-87 Civic Flush headlight
    By hoxz in forum Honda Swap Meet
    Last Post: 02-12-2013, 01:06 AM
  3. Wtb TA40 headlight bezel
    By my_zyen in forum Toyota Swap Meet
    Last Post: 05-03-2012, 12:32 PM
  4. MX73 Headlight Washers. PNW.
    By jp patches in forum Toyota Swap Meet
    Last Post: 02-29-2012, 09:37 PM
  5. mx32 headlight issue... F*CK!
    By shane_lxi in forum Toyota Garage
    Last Post: 10-23-2009, 12:08 AM
