Results 1 to 10 of 13
Thread: 1977 Datsun B210 Poor MPG ~Please help
    Sep 2010
    Rolla, MO
    14
    Alright, so my Datsun B210(automatic trans) has a new distributor, a new fuel pump, a new condenser, new points, new spark plugs, new carburetor and new wires and yet it is barely getting 17 mpg. I'm pretty sure it should be getting around 30 mpg. Any suggestions as to what I should do/check?
    Aug 2009
    austin tx
    65
    are you having any other problems? smoke, sluggish behaviors, dried cement in your trunk?
    Sep 2010
    Rolla, MO
    14
    Re:
    Sadly, no dried cement in my trunk. Darn.
    My car does have a lot of trouble going up hills though, but I assumed that since it has such a tiny engine it just doesn't have much power to chug up big hills.
    It drives in town fine, just slow acceleration, but once again, I thought simply because it is an "impressive" 4 cylinder engine.
    The exhaust has been pretty horrid lately, and I know it is not the fuel mixture since I had it recently adjusted to its proper specs (before it was too rich).
    On the highway it can go about 65 max. After that it struggles.
    When I bought the car they said it had not been driven for a while. I have been driving it for 3 months with no improvement and I have put in fuel treatments/cleaners.
    Thats all the info I can think about that might be helpful.
    Guest
    Maybe a plugged exhaust system?
    Mark
    5,530
    Yeah, I'd start looking at the exhaust system. Plugged catalytic converter maybe? If it ran too rich for too long, that can happen.
    Aug 2009
    austin tx
    65
    you shouldnt be having acceleration problems with a healthy a14, its a small motor holds up well enough. personally i would start with the PCV valve, i had one that broke open and had all the problems your describing although my idle was almost nonexistent too. does the exhaust generally only occure on acceleration?
    Sep 2010
    Rolla, MO
    14
    My car has no catalytic converter. My exhaust looks normal, it just smells bad sometimes but I didn't notice the smell today. The idle is very firm/normal.
    I took it to a few mechanics, and they said that I will have to redo the fuel mixture after a while since it is a new carb(seals expand and all that).
    They also said it might not be getting the mpg it should because the gas in the USA now has ethanol in it (which is not good for my engine apparently or any car still using a carb)
    5,530
    Quote Originally Posted by gcq4nb
    Are you 100% sure? I know most '77 Datsuns didn't, but problems with the cat will also cause it to have a really bad smell... :P
    Sep 2010
    Rolla, MO
    14
    100% sure, I had a mechanic that specializes in exhaust systems look into the plugged converter theory, and he said there wasn't even one installed.
    Plus I looked myself.
    Aug 2009
    austin tx
    65
    sorry, but did you check the PCV valve yet? its located just below the carburetor on the in intake manifold connected to the only hose thats coming out of the back of the motor, pull the hose off and stick a screwdriver in the valve, it should feel like poking a spring.
    that ethanol shouldnt have that much of an effect -i still get about 28 mpg on my '76, and your loss in power proves other problems.
  1. So. Cali ~ 1977 Datsun B210 Front Grille NOS Brand New
    By ekdc in forum Datsun/Nissan Swap Meet
    Last Post: 11-09-2012, 04:02 PM
  2. Where is the fuse box for Datsun B210?
    By Kev3 in forum Datsun/Nissan Garage
    Last Post: 08-22-2011, 01:35 PM
  3. 1977 Datsun B210 Engine Trouble PLEASE HELP =(
    By gcq4nb in forum Datsun/Nissan Garage
    Last Post: 07-04-2011, 08:51 PM
  4. Thinking up ideas for my cute 1977 Datsun B210
    Last Post: 11-14-2010, 04:35 PM
  5. Anyone have a Hot Rod Mag with a Datsun B210 cover car?
    By Stationwagonguy in forum General Discussion, JNC News & FAQ
    Last Post: 12-01-2009, 10:33 PM
