Results 1 to 6 of 6
Thread: Coolant Temperature Sensor in mazda 323 model 1985
    Sep 2010
    Greece
    3
    Hi everybody
    I have a mazda 323 model 1985 (or 1983, I'm not sure, I't my father's).
    The problem is that the radiator fan does not switch on.
    On the housing of the thermostat are mounted two "bolts" (one of them is the Coolant Temperature Sensor, the other I don't know), each bolt is connected with a cable.
    When I disconnect one of these two cables that go to the thermostat housing, the radiator fan switches on and works fine!
    So I think that the Coolant Temperature Sensor is malfunctioning.
    Also, the thermometer (temperature meter) is not working. Is it using the same sensor?
    What do you think?
    Mar 2009
    netherlands
    79
    switched wires, perhaps?
    Sep 2010
    Greece
    3
    What a thought!!!
    What do you mean?
    That maybe someone has switched the two wires connected on the two "bolts"? If that's what you mean, it`s not impossible! Not at all!
    Do know what is the second "bolt" used for?
    The first one is the Coolant temperature sensor.
    The other? Is this the thermometer sensor, maybe?
    Dec 2007
    Norway
    10
    Different sensors.
    There's a failsafe on these older mazdas.. if you unhook the temperature sensor for the fan, it runs as long as the ignition is on.
    The other sensor is for the thermometer in the car, check the wire and connector if its damaged/corroded.
    These sensors should be fairly easy to source from mazda though, even for an '85 323
    Mar 2009
    netherlands
    79
    Re: What a thought!!!
    Quote Originally Posted by panoss
    What do you mean?
    The temperture switch for the fan and the sensor for your teperturemeter are usualy quit close to eachother. I don't know if it's possible, but if both wires are switched (teperture switch on the temperture meter and the sensor on your radiator fan), it would explain why both are not working.
    Sep 2010
    Greece
    3
    The two jacks (connectors? don't know the excact term) are different, so can't be switced.
    Finally both of them (the sensors) were burned, I replaced them and everything works fine!
    I thought thar maybe there had been produced an overvoltage and that burned them. I suspected a bad erthing of the dynamo (alternator) but it's ok, it gives 14.6 Volts at 4000 rpm of the motor.
    Everything works fine up to now, thank you for your help!
  1. DR30 coolant temp sensor - Tridon part no?
    By Orion in forum Datsun/Nissan Garage
    Last Post: 10-31-2013, 05:44 AM
  2. Looking for a scale model of a Mazda RX-2
    By jonesyGT in forum General Discussion, JNC News & FAQ
    Last Post: 11-18-2012, 12:59 AM
  3. 1985 Mazda GLC 91,000 km Value ?
    By Robb in forum Mazda Garage
    Last Post: 10-24-2011, 10:30 PM
  4. 1987 Mazda RX-7 base model..
    By daddsun in forum Mazda Garage
    Last Post: 10-02-2011, 01:13 PM
  5. 1985 Mazda RX-7
    By SevenHeaven in forum Mazda Garage
    Last Post: 02-10-2011, 08:22 PM
