Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: breakerless??
    Apr 2010
    philippines
    134
    breakerless??
    is there a breakerless ignition that can be retrofitted to a chain drive 4g32 motor?
    Feb 2008
    scappoose, or
    754
    You could do pertronix. According to this it should fit.
    http://www.streetperformance.com/part/p ... u-141.html
    Or try adapting something off a later mitsu electronic ignition.
    There isnt a bolt in electronic dizzy as far as i know though. I dont think the 4g37 will bolt in.
    May 2010
    Sarasota, FL
    10
    Good question.. quite interested too.
    Quote Originally Posted by city hunter
    Has anybody tried installing this?
    Feb 2008
    scappoose, or
    754
    You find them quite often on older datsuns. I had something similar to this on my 240z, but it was some other sort of ignition setup.
    May 2010
    Sarasota, FL
    10
    I checked on that link and contacted streetsideauto, was planning to get one but had second thoughts when I found out that there's a no return policy on it once installed.
    Feb 2010
    Cleveland, Ohio
    1,608
    I have a Pertronix Flamethrower setup on my MGB and I love it. :tu: Someone told me that leaving your key in the ignition will drain your battery very quickly, though, once installed.
    Feb 2008
    scappoose, or
    754
    might be correct, I seem to remember my coil getting very hot without the car running and the ignition on.
    May 2010
    Sarasota, FL
    10
    that's what i'm afraid of, or worse..if it won't work with my stock dizzy and I'd be stuck with it.
    Feb 2008
    scappoose, or
    754
    call pertroinix up and ask them about it.
    May 2010
    Sarasota, FL
    10
    Yup, I did call them a couple of months ago. They asked for the code stamped on the dizzy, gave it to them & they said that they don't have any to match it.
  1. Toyota K engine, breakerless/electronic ignition set
    By pahl_7 in forum Toyota Swap Meet
    Last Post: 04-24-2011, 04:19 AM
  2. Toyota K engine breakerless distributor set
    Last Post: 10-31-2010, 12:37 PM
