Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 1969 Toyota Corona rt52 Coupe
    Sep 2010
    East Bay, CA
    25
    All original from what i know. The odometer is frozen up at 9600, which seems common on these old Toyota's. Its got a 3RC with a Toyoglide 2 speed on the floor. The transmission doesn't leak at all, but doesn't seem to like being in low gear very much. Not sure if there are adjustments on this? The engine does not run very well which i am 95% sure is because the distributor is not advancing properly. As well as not running right its leaking oil pretty good too. Should be a fun little project.
    This thing has been really fun just cruising around town and what not, getting a lot of attention and questions. I hope that i can daily drive this little beast and eventually upgrade the engine/tranny to something with around 150-200hp.
    Let me know what you guys think.
    Sep 2010
    East Bay, CA
    25
    Bump
    Sep 2010
    East Bay, CA
    25
    Jan 2008
    Villeneuve, Qld, Australia
    508
    Welcome aboard, man that is sweet!!
    Jun 2008
    Torrance CA
    277
    Very nice. I have already done what you are looking for. 170HP 18RG with a 5 speed. its even more fun!
    Mar 2010
    Chicago
    163
    looks nice! i'm working on getting mine roadworthy. just need new brakes and patch up a hole in the exhaust pipe.
    you should be able to get the odometer rebuilt for cheap. i spend $35 to get the speedo/odo rebuilt here in phoenix.
    Sep 2010
    East Bay, CA
    25
    Quote Originally Posted by moominsean
    pulled the drums off yesterday and all four corners are almost brand new shoes. the muffler is completely rotted out on the inlet side as well, makes it sound pretty beast.
    Is there any good reason to remove the smog pump? What exactly do i need to do? Almost seems like it would be a first gen belt driven supercharger
    Mar 2010
    Chicago
    163
    my smog pump was disconnected a long time ago. i was told it was a common thing to do, though not sure why. one less thing to maintain, or better performance maybe.
    for questions and parts, email carlyn at cdinkler@bellsouth.net.
    May 2010
    cali
    149
    very clean car i have a 70 corona mark II where abouts are u in the east bay?
    Sep 2010
    East Bay, CA
    25
    The timing does not work properly which i determined to be the vacuum advance. I took the vacuum line off from the carb to the distributor and found a nail that was shoved up inside the tubing to block the airflow. It was all hooked up and looked as if the vacuum advance would be working just fine.
    Now answer me this. Why would anyone ever block the vacuum line to their
    vacuum advance on their distributor?
    Here are some more pictures for you guys (i know moominsean will appreciate the pics our cars are basically twins)
  1. WTB: RT52 Toyota Corona Weather strip Kit...
    By Rt105Bong in forum Toyota Swap Meet
    Last Post: 07-22-2013, 08:52 AM
  2. my rt52 corona coupe
    By SOdrifter in forum Toyota Garage
    Last Post: 06-07-2013, 02:05 PM
  3. 1969 Toyota Corona deluxe Rt52
    By Sammsunng in forum Toyota Garage
    Last Post: 11-28-2012, 05:22 AM
  4. 1969 Toyota Corona rt52
    By matchan420 in forum Toyota Garage
    Last Post: 11-13-2012, 08:16 PM
  5. Toyota Corona RT52/Ford Taurus??(pics.)
    Last Post: 02-05-2010, 05:18 AM
