Results 1 to 10 of 13
Thread: Japanese plate bolts?
    Jan 2008
    Jersey City, New Jersey
    296
    'Just need help on identifying what this bolt cover is called in Japan and what it means.
    Thanks!
    Jan 2008
    296
    After searching for more than an hour...
    They're prefecture seals installed to keep the driver from moving the plate to another car.
    (Mods feel free to delete since I already answered my own question)
    Thanks again!
    5,527
    Quote Originally Posted by JunRaymond
    Why delete it? Someone else may have the same question later. :wink:
    Nov 2008
    Strasburg, VA
    508
    wow. what if i need to clean underneath the plate?? what do i do then!?!?!
    Jan 2008
    296
    Alright :tu:
    From Wikipedia: "The plates are installed in both the front and rear of the vehicle, with the rear plate permanently attached to the vehicle with a prefecture seal completely covering one of the attaching plate bolts."
    5,527
    Quote Originally Posted by e-at_me
    You don't. :P
    Or like with almost every other state mandated thing, you find ways around it... :wink:
    Jul 2007
    Midwest, USA
    285
    ...like with almost every other state mandated thing, you find ways around it... :wink:
    That's funny, the top two examples that JunRaymond posted are the glowing plates (light boxes with translucent green letters that light up with the parking lights. They are illegal. So at least two people did find a way to remove and replace the seal in order to install the glowing plates.
    Sep 2010
    Albuquerque NM
    240
    Quote Originally Posted by JT191
    negative, the glowing plates are not illegal.
    your best is to put on an adjustable plate bracket, then buy another seal and have them put it on.
    Jun 2008
    Auckland, New Zealand
    351
    The best site I've found that explains the Japanese licence plate system in proper detail:
    http://www.tigerdude.com/japan/license/
    Jan 2008
    296
    Quote Originally Posted by Orion
    'Knew this site but really forgot about it. Thanks Orion! :tu:
    From tigerdude.com
    "Most vehicles > 660cc, have an official seal or neji protecting the upper left screw on the rear plate. It is a lock-tab-button which prevents plate swapping and theft. The registration isn't official unless this seal is in place. These seals have been in use since after the War, and certainly were in place when the number plate system saw standardization in 1951."
  1. wtb: bolts for volk mesh split rims
    By Fege in forum Wheels Swap Meet
    Last Post: 03-09-2015, 05:18 PM
  2. HELP!! Need U-bolts for TE61 rear axle.
    Last Post: 07-07-2014, 05:11 PM
  3. Nuts bolts and Screws
    By 8803 in forum Honda Garage
    Last Post: 04-16-2012, 02:22 PM
  4. Specs of Flywheel Bolts for 4g52 Engine?
    By burgggie99 in forum Mitsubishi Garage
    Last Post: 12-07-2011, 08:06 AM
  5. Japanese license plate questions
    By john in forum Off-Topic
    Last Post: 01-11-2010, 03:33 AM
