Results 1 to 4 of 4
Thread: 1980s subaru, custom beam
    Dec 2008
    maine
    64
    thought I would share this. I hav a 1987 subaru, dual rnage. My neck of the woods breaks these like candy in the darndest places...just staying road worthy. :roll:
    I found two beams that really needed to be there. I made some..
    if you can decipher above, it gently meets the center carrier in the tunnel, and the square end is where the rear seat bolts go through...
    the other end is this:
    and here is another angle:
    this has proven to fix every other error I welded. I am in 12 full mig reels, 2 pounds a pice.. and greater than 32 sq feet of sheet, and 4 spring steel rods.
    I could have save alot of effort with these beams installed...your creaking sube is telling you something. :wink:
    one final shot:
    Aug 2007
    Albany, NY USA
    95
    Thanks for sharing your work with us. So you added those beams to fix a creaking problem or was the car falling apart from rust?
    Mike
    Aug 2007
    Albany, NY USA
    95
    I think it's great that Subaru ran the fuel and brake lines inside the car to keep them corrosion free. Nice!
    Dec 2008
    maine
    64
    Re: 1980s subaru, custom beam
    been nearly 5 years for this post.
    Still have the same car. now registered as antique.
    Alot of work since then, but I'll add facts on the engine. Engine #3..
    The engine is extremely rare, from a 1985 subaru RX. A 1 in 1500 on the production. Upon my own experience of 17 years non-stop.. I built my version of an EA82, using the best of everything from a 1985 to 1994.
    multiport turbo heads
    sodium filled valves removed for loyale version
    simply cleaned up
    new valve seals
    these heads do indeed have a liner added to the coolant side to be tougher.
    loyale shortblock, healthy.
    loyale cams, turbo casings (fat bottom bearings)
    intake and cam casings baked with silica based paint.
    compression is near 10 to 1.
    fuel is summit 140gpg, full return, pressure regulated, 43mm rochester carb.
    exhaust is equal header, alot of stainless. no smaller than 2 inch.
    clutch is spec stage 1 - this car would not take off with factory clutch.
    15 inch peugeot wheels 205/60/15 bf goodrich
    ignition is msd 6530 with map sensor, 8,8 mm wires, and subaru optical.
    cooling is brass copper CSF radiator, exact fit for this generation (not easy to find)
    nissan 90 amp alternator, direct fit.
    I built this in january, has not had a proper burn in yet. Awaiting warmer weather. Without surprise, it simply sounds like the first of the EJ series engines in the early 90s..with a little more hummingbird at idle.
    All lights are LED... alot of things not mentioned.
    congrats on the drive episode, attention deserved.
  1. Is this OEM, Aftermarket, or Custom?
    By cesariojpn in forum Toyota Garage
    Last Post: 12-28-2012, 05:18 AM
  2. 1980s Translated Twincam brochure
    By ToyGuy in forum Toyota Garage
    Last Post: 01-20-2011, 11:09 AM
  3. HID housings for sealed beam
    By adamyee in forum Toyota Garage
    Last Post: 10-30-2010, 01:33 AM
  4. Subaru 360 Sedan acelleration test w/ custom expansion pipe
    By 2stroketurbo in forum Subaru Garage
    Last Post: 03-28-2010, 02:45 PM
  5. 1980s rear end "tube"
    By boxer3main in forum Subaru Garage
    Last Post: 03-16-2010, 04:09 PM
