Results 1 to 6 of 6
Thread: Big wheels for Honda 600
    Mar 2009
    Portland Or.
    186
    Hi gang!
    does anyone have any expirience or pictures of 4x110mm bolt pattern 13" wheels on a Honda 600?
    I've heard it will work but never seen it done. I assume 185-50-13 tires or maybe even 205's may fit.
    Early Mazda Rx7's and early Corolla's have this bolt pattern but those wheels are really hard to find.
    I think it would look cool. There is so much fender clearance on the 600, they look jacked up with stock 10" wheels.
    Mar 2009
    Portland Or.
    186
    Oh, I forgot. Here is my new Car:
    http://www.youtube.com/watch?v=PBmfViM5MhM
    I love it.
    Dec 2009
    sacramento
    141
    I fitted rx7 wheeels and 205/50 13 tires to roll my Z around before i got more 10"ers. the rear rubbed the instant you sat in the car and you could barley steer the front wheels. i tried 185s but they were even taller. w/o cutting the fender arches, 10" is the only way to go i see
    Jul 2009
    Essex, UK
    37
    I've got 13's to go on mine but am using 175/50r13, it is only a tiny bit larger than the 165/7010#'s it runs today so i am hopeful it will fit.
    My car does have flared front and rear arches though.
    I think it'll look quite cool when done, you can also use 12's, whcih is the way I'm going on my more stock spec N600.
    There are pics on this link of both the N600 and z600 with 12's and 13's.
    http://www.auto-otaku.com/home/2008/02/ ... s-mee.html
    Getting the 175?50r13 tyres may be an issue for you guys in the US but they are a size used on the mini sportpack cars in europe and as such you can buy several brands inc Yokohama A048R's whcih is what i'ev got.
    Jan 2008
    Melbourne, Aust.
    87
    RX7 RWD offest is always going to stick the wheels waaay out there!
    Corolla & Mazda 1300 that old would be 12" wouldn't they (& also RWD)
    I got some '89 Daihatsu Kei car 4x110 12" wheels that should work though wheel-stud holes are a bit oversize for hondas tiny bolt thread...
    Mar 2009
    Portland Or.
    186
    Thanks for your input guys. Acording to you, It seems the 13" wheels are not such a good fit. 175-50-13's are unheard of here. I plan to clean up the stock 10" rims and get some sticky 10" Yokohama A008's
    http://www.tirerack.com/tires/tires.jsp ... num=67HR08
    Although they are spendy $$$!!. Anyone know of a good sporting 10" tire that may be cheaper?
    Thanks again.
    Mark
  1. (5) 1985 honda crx si 13 inch wheels
    By 82bosolude in forum Honda Swap Meet
    Last Post: 07-15-2013, 04:37 AM
  2. 4x120 Appliance wire wheels for early Honda
    By AZhitman in forum Wheels Swap Meet
    Last Post: 03-19-2013, 10:18 PM
  3. Hot Wheels Honda CR-X...
    By jtl46 in forum Honda Garage
    Last Post: 10-08-2012, 01:43 PM
  4. Hot Wheels 2010 Toyota Tundra and Honda S2000...
    By jtl46 in forum General Discussion, JNC News & FAQ
    Last Post: 05-19-2012, 04:58 AM
  5. Replies: 2
    Last Post: 07-27-2010, 04:44 PM
