Results 1 to 10 of 19
Thread: finale
    Apr 2010
    philippines
    134
    finale
    anyone here knows all the final gear ratios for all rear drive mitsus and their designated models?, like 3.89 comes from model xx with 5 speed
    and which are interchangable with other models, lets say 4.22 from 84 lancer to be fitted on a 74 galant with 3.89
    8)
    Administrator JNC's Avatar
    Mar 2007
    Socal
    1,643
    all models? :shock:
    -Matt
    Feb 2008
    scappoose, or
    754
    uhm 84 lancer should share the 170mm diff with the I believe galant lambda, and sigma I believe? 74 galant is smaller I think.
    You should just ask what gears you want and what ratio.
    Apr 2010
    philippines
    134
    Quote Originally Posted by matt
    all models? :shock:
    pretty much, if possible, or perhaps only those interchangables
    Feb 2008
    East Wallyworld Vermont USA
    99
    Quote Originally Posted by motorhedz01
    all models? :shock:
    That would be about an hour of writing.
    There are 3 different gear sizes in the cars, 170, 180, and 200mm.
    In the 170mm common in the smaller cars as well as all 2 liter and smaller AWD platforms you need to watch for light and heavy gearsets.
    The ratios commonly available in 170mm axle Mitsubishi's are 2.86, 3.308, 3.54, 3.89, 4.22, 4.625, 4.88 & 5.38.
    Apr 2010
    philippines
    134
    Quote Originally Posted by Old Colt
    all models? :shock:
    thanks, the only ones i'm aware of are 3.89s and 4.22s, its because recently i swapped(and counted them out of curiousity) a 4.22s from a lancer boxtype differential(ones with rear disc brakes) to 76 colt galants 3.89s, along with a 5 speed trans from i dont know what mitsu it came from and there was a slight difference from the old 4 speed, the shifter move backwards about two inches(the crossmember also moved but the chassis had provision) but the tranny is of the same length as the driveshaft fits the same position, i'm wondering too if there is a tranny that will fit excactly and from what car(mitsu) it would come from?
    Feb 2008
    99
    What engine are you working with?
    Apr 2010
    philippines
    134
    4g32(timing chain), the thing that i mean excactly is the shifter/gear lever position, i got no problems with the bellhousing and mountings/support/crossmember, all is good except for that, i had to cut and fold the floor an inch to clear some space for it ops: 8)
    Feb 2008
    99
    The little KM118 5 speed is the best transmission for that. It is the one with the two upper mount holes on the left side so it will bolt to both a G32 or to a standard narrow block such as the 2L engines.
    And yes the shifter is back a little bit on most of them. Kind of a PIA if you have a console but otherwise the shifter opening needs to be adjusted.
    Apr 2010
    philippines
    134
    not quite sure about the two upper mount holes but i'll try to check them tomorrow morning, also, i read that there is a 5 speed 76 galant, though i think its the 2 liter(4g63), will that transmission from 4g63 fit the 4g32 and vice versa?, the 5 speed for 4g32 to 4g63?, cause we're planning to swap the 4g32 to 4g63(from an L300) later.
