Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: 1986 daihatsu handivan
    Aug 2010
    Sydney, nsw
    29
    hi all,
    like the other guy ill-minded, i too am building a handivan. why? 2 reasons, for sh*ts and giggles; and because i can.
    i bought it off a local sydney guy from ebay for 300 bucks with 6 months rego. i picked it up on june 30th last yr. i remember this date because it was my last day at my previous employer; out whole team got made redunant due to GFC. i've been tinkering with it from july through to the start of this yr.
    its been sitting in my garage doing nothing since because i found a new job, have family committments, and because daylight savings ended and it was getting too cold to work on the car.
    now that daylight savings is coming back and a google search found ill-mindeds handivan, i think i should get out in the garage and do something.
    anyway, this is a fun car to drive being so small but it is pretty embarassing when you get weird looks.
    Aug 2010
    Sydney, nsw
    29
    this is what it looked like when i bought it
    if you look closely my car has a sunroof (which isnt standard); i plan on removing it.
    it was lowered (springs cut) by the previous owner (p plater kid who used it as his daily driver to and from work).
    the plan at the time was to fix it up so it was more driveable and just have fun with it. as we all know, that goes out the window when you start searching on the net for parts.
    i started tearing the car apart to reduce the weight as much as possible and i ended up removing the aircon assembly and all sound deadening material from the interior
    i thought it would be a funny/stupid idea to buy a ramtube/trumpet from ebay and replace the carburettors airbox like this
    heres a video of what it sounds like
    some various pics of the car throughout various stages (in no order)
    Aug 2010
    Sydney, nsw
    29
    things i plan to do
    660cc pistons into the 850cc block
    replace rear windows with sheet metal. this guy (random who once in a while parks in my street) did it to his car and its got rego, so it'll pass for me too?
    upgrade the crap 210mm solid brakes to daihatsu applause 234mm vented brakes. this is a straight swap, no mod required.
    i also picked up sirion rear drums to keep the stud pattern the same as the front so when i find rims.
    while unemployed i had the luxury of spending 8 hour days (no joke) at a wrecking yard where we can pull off car parts ourselves. there was a handivan in the yard i used as a test mule for interchanging parts from all of the daihatsu line up.
    threw out the old handivan seats for applause seats. seat rail swap required.
    cut the bumper to widen the hole. just felt like doing it
    rolled the guards with a bamboo pole (insert jackie chan saying 'chinese bamboo vely strong' joke here hahaha). i'll have to do this properly later on
    Aug 2010
    Sydney, nsw
    29
    bah, pics of before the rego ran out and i stripped the car back again
    at the moment it has a thick coat of dust on it; its on jackstands with the wiring removed, engine ready to be pulled out and half of the brake swap completed. its been like that for 4+ months
    Jun 2010
    Brisbane, Australia
    341
    ahhh nice. someone else with a handivan
    your's looks to have a a better shell than mine (few minor fender benders on the drivers front and rear corners). handy knowing that applause seats will fit. mine are looking a bit ragged looking. i have to say though, it's great working on one of these given how simple they are and how little there is in them haha.
    regarding the engine, do you intend to use the EF head off the L200/L500 mira as well as the pistons, or just the pistons by themselves?
    also, what's still left on the handivan in the wrecker? i'm still chasing a few small parts for mine which i may look into if i can't find one locally. parts i can think of off the top of my head: steering column surround, radiator, dizzy.
    anyway, if you've got any questions, gimme a buzz. i'll do likewise if i run into anything :P good to have someone to refer to, as i've found that there isn't really a lot of interest/support for these.
    cheers
    Aug 2010
    Sydney, nsw
    29
    I actually think your shell looks better than mine. There dings, dents and cracked paint in lots of areas. I found rust on the bottom of the windscreen when i pulled out the dashboard so i'd have to fix it.
    The applause seats are so much mokre comfy than the handivan seats. I remembered that with the rail swap, it was more than i could do myself so i took it to an upholsterer to do the work and retain the fabric (if i did it meyself i would have torn it). For a small fee they did a great job.
    That white handivan at the wreckers is long gone, but i'll be on the lookout for any spares you need. A charade radiator fits into the handivan, some guy in jamaica on another forum did it.
    As for the engine, like you i plan on keeping it carburetted. I was thinking of using the 660cc head but then you'd have to use the efi intake manifold.
    I'll use the 660cc pistons but i know i need to shave the top of it off otherwise the valves would hit it.
    All of my research was done about a year ago and scribbled on pages cause my memory isnt the best!
    I pulled the carb off my engine and the manifold ould use alot of port and polish work done to it, but youre going to use motorbike carbs? That would be pretty cool.
    It looks like we're the only two handivan owners in australia that are keeping the engine carb'ed, good luck!
    Jun 2010
    Brisbane, Australia
    341
    haha, i had rust in the top around the windscreen, and rust along the channels in the roof. roof has dents, drivers door was sagging (fixed that though) and has dents, both rear corners have dents, hatch is pretty bent. front right drivers seat mount has been torn out previously and fixed. previous accident damage on the front and rear drivers quarters, cracked windscreen, both window winders/regulators borked, engine not running, gearbox leaking oil... the list goes on :P at least you've driven yours haha.
    no problems bout that handivan at the wreckers. i'll make do with what i can with the two L200s at the local wrecker and swap and change parts out of other daihatsus. i'll probably grab a radiator from an L200 and zip tie it in since the top mounts are different.
    i had plans to use the EF 12 valve head, cut out a steel flange and weld some pipe to it and attach some snow-mobile/ski-doo carbs (similar to this) and attach them with silicon joiners. i have a mate who can tune and modify carbs, so that's not too much of an issue. for the time being though, the standard motor with a fresh rebuild is all. modifying comes later when i have the money to justify it haha.
    Aug 2010
    Sydney, nsw
    29
    Haha you win. The car is definitely fun to drive no doubt.
    You're lucky to have a mate that can help; i have mechanic/sparkie friends but they have their own business to run and they live too far away now (i moved away from my home town).
    I need to learn how to weld, it'd definitely help me with experimenting with some under body braces and DIY exhaust.
    I think my future plans for the car is to build it for circuit use. It wont break records but it would be good to improve driving skill. I just hope it doesnt limit driver skill. Later on i'll register it for the road or probably sell it.
    Do you have a budget for the car? I initially gave myself $2000, so far i'm at $1700... Buying unnecessary junk always gets the better of me.
    Jun 2010
    Brisbane, Australia
    341
    welding is a great skill. i'm far from good at it, but i can do it well enough to be reliable. though, that's what a large part of this car is for. it gives me something to practice skills on before i go and attempt anything on my celica, so i don't muff it up :P
    current budget is as cheap as i can go. i think current expenditure is around about $200-250 including the price of the car itself, so with any luck, i can have it running for under $1k, then rego and drive it daily
    Dallas TX
    69
    I really wish we got cool kei cars here in america.. so lame that we didnt..
    I want an awd turbocharged tiny monster in my garage..
  1. 1986 Daihatsu L70/L80 Mira/Handi
    By ill-minded in forum Other Marques Garage
    Last Post: 08-22-2015, 08:47 AM
  2. 1964 Daihatsu Hi-Jet L-35
    By DevilDeVille in forum Other Marques Garage
    Last Post: 09-22-2013, 12:53 PM
  3. Daihatsu EF-HL parts
    By Joyride in forum Other Marques Swap Meet
    Last Post: 06-28-2011, 12:44 PM
  4. Daihatsu
    By Midget in forum Introduce Yourself
    Last Post: 06-16-2011, 10:59 AM
  5. Daihatsu Charade G10
    By in forum Other Marques Garage
    Last Post: 07-02-2009, 04:55 PM
