Results 1 to 10 of 20
Thread: NX1600 Digital Cluster in a Zenki S13
    Oct 2009
    Lake Worth, FL
    11
    Yup, A digital NX1600 cluster in a 89 240 coupe. It was hard, believe me, but I did it just to put away rumors that it couldn't be done, and to shut a few people up. The wiring was the hard part, Thanks to Fireblade RX-7 for all the wiring help, dude your the best. I didn't need to use the NX speed sensor, or the temp sensor, because I have a twin cam swap with a 89 single cam tranny, and I guess the 89 tranny speed sensor puts out the same pulses per revolution as a NX speed sensor. But any way here are the pics.
    The rough harness right after it was made
    Modifying the cluster garnish mounting plate thingy
    After Modification
    Had to cut away plastic at the base and the top of where the cluster sits because it the cluster is so tall it was hitting the bottom and the top of the cluster pod.
    Cleaned up Harness
    Cluster Mock up
    Here are some shots of it/me in action
    Me, lol
    The car it was swapped into
    May 2009
    cen cal
    10
    looks awesome. love the tach layout
    Jan 2007
    3,108
    That looks awesome! Modern, yet era-appropriate.
    Mar 2007
    North East United Kingdom
    213
    WoW so are these in the US version of the 100NX ??
    I'd love to get one of these for my girlfriends NX
    Oct 2009
    Lake Worth, FL
    11
    Quote Originally Posted by drive-by
    Yup, It was available in the 1.6L versions here in the states, called the NX1600.
    Thanks guys, glad you like it!
    Mar 2007
    213
    [quote=ShutokouMasteR S-13]
    Quote Originally Posted by "drive-by":2bu4bibi
    Thanks guys, glad you like it![/quote:2bu4bibi]
    Thanks, just snapped one up for her. :tu:
    Oct 2009
    Lake Worth, FL
    11
    [quote=drive-by][quote="ShutokouMasteR S-13":2668t4vx]
    Quote Originally Posted by "drive-by":2668t4vx
    Thanks guys, glad you like it![/quote:2668t4vx]
    Thanks, just snapped one up for her. :tu:[/quote:2668t4vx]
    I am not sure about the interchangeability of the NX clusters, but you might have to do some wiring to make it work. What year is her 100NX, and does it have a tachometer in the current gauge cluster?
    Oct 2009
    Lake Worth, FL
    17
    As long as the speed sensor is compatible (2 wires, pulsed signal, X number of pulses per revolution or whatever) you can make any 4 cylinder cluster work.
    Mar 2007
    213
    Quote Originally Posted by ShutokouMasteR S-13
    Its a 94 and yes it has Tacho too. If it can be made to fit an S13 I'm sure I can make it fit the NX
    Oct 2009
    Lake Worth, FL
    11
    Yea it'll fit and mount up perfectly, all the B13 and NX clusters mount the same way and are shaped the same way, so you'll have no problem, just some minor wiring. Hope it works out!
  1. Toyota Corolla ZENKI decals *1UZFE equipped*
    By micro214_kp61 in forum Toyota Swap Meet
    Last Post: 04-17-2014, 06:41 PM
  2. Wtb zenki engine harness
    By Dominican365 in forum Toyota Swap Meet
    Last Post: 10-28-2012, 02:29 PM
  3. Ae86 JDM zenki Coupe tailights!!
    By laylow909 in forum Toyota Swap Meet
    Last Post: 04-10-2012, 07:10 PM
  4. very rare! VegliaDigit digital rev counter (Tachometer)
    By 2ylytwrld in forum Wheels Swap Meet
    Last Post: 07-13-2011, 06:30 AM
  5. ae86 zenki tail lights
    By nimbus2000 in forum Toyota Swap Meet
    Last Post: 06-22-2011, 04:55 PM
