Results 1 to 9 of 9
Thread: Wide Wheels= Bearing damage?
    Aug 2010
    dallas, tx
    23
    I love wide wheels...
    I find somewhat unclear results when I try to google it and I didn't see anything by searching for it on this forum. Can anyone here say that wider wheels mess up your wheel bearings? I don't race, I just drive, and I'm only thinking about going from like 15x6.5 to 15x8 or 15x7.
    If anyone can share I'm interested in knowing if there are any cons about going wider... It just seems like all cars should have wider wheels to me...
    Guest
    Where you run into bearing problems is usually with FWD cars running big negative offsets. Puts a lot of force at the end of the bearing instead of centered over it.
    Mark
    May 2010
    cali
    149
    i rocked 15x11 -70ish and 15x13 -94 on my scion xb the bearings did not like me and i didnt drive the car that often
    Aug 2010
    dallas, tx
    23
    I'm looking at 15x8 with a +4 offset... I think that gives me and extra 55mm on the outside and I think it was a 16mm clearance between the strut and wheel on the inside. Asuming there's no grind on the tire, I hope that sounds not too bad.
    Uhh, I'm scarred... I've had a bad experience with bearings, I had trouble finding people who could press them right... they always told me they could do it and then a few weeks later... RRrrrr RRrrr RRRrrr (bad bearing noise).
    OK yellowsub... those were huge (I'm sure they looked great)... but it seems to go with Mark's comment.
    My +4 offset isn't a big negative offset but it's 5mm from being a negative number. Do you guess this will still cause problems... or know from experience?
    a FWD corolla I have 1988 2 door
    May 2010
    cali
    149
    u should be fine with those offsets those arent very aggressive and wont add much stress to the bearing
    Jul 2007
    Midwest, USA
    285
    If you want to widen the track without risking bearing damage, about the only way is to do a wide body the hard way. Use longer trailing arms, longer tie rods on the steering rack, and longer axles. But you would have to redo all the spring rates and damper settings to match the longer trailing arms.
    Or, move the suspension mounting points out.
    Select a wider wheel with the same or close to the same offset. Then the load on the bearing is not changed and the wear rate remains the same.
    The bad part would be if the whole reason for wanting wider wheels was to have the wheel face set deep back from the edge of the rim, because all those changes to preserve the bearing do away with that appearance.
    Apr 2009
    Central Fl
    196
    the wrong offset and backspacing will effect the wheel bearings and the ball joints it is a alignment angle called scrub radius
    which is a line drawn throught the pivot points of a front end ie ball joints and top of strut or through both ball joints and where that line intersects through the imaginary vertical of the tire and rim
    and how much pos or neg scub affects bearing and ball joint wear
    Mar 2007
    Tasmania, Australia
    219
    Short answer without the engineering guff, and ignoring front wheel drive crapboxes is..
    No.
    Low offsets and wide wheels won't destroy wheelbearings unless they're already finished.
    End of the day more stress on bearings? Yes. Tangible effect in reality? No.
    Jul 2008
    Alabang, Philippines
    46
    I've had 14x6.5 +15 offset (front) and 14x8 0 offset (rear) on my Lancer for over a year and have been driving her pretty hard and racing. No issues with the bearings.
  1. FS:[NJ] *RARE & WIDE* Epsilon Mesh Wheels 4x100
    By Drock30 in forum Wheels Swap Meet
    Last Post: 04-25-2015, 05:57 PM
  2. WHERE TO BUY WIDE JAPANESE OLD SCHOOL WHEELS
    By serchmarc in forum Resto Tips, Wheels & Other Goodies
    Last Post: 07-11-2013, 08:06 AM
  3. WTB: Wide, low offset 14" old school wheels (4*114,3)
    By fredriksoerlie in forum Wheels Swap Meet
    Last Post: 03-22-2012, 03:32 AM
  4. 2 Wide Baby Supra wheels - $100 NYC
    By TransAmBandit in forum Wheels Swap Meet
    Last Post: 05-25-2011, 04:45 PM
  5. well new damage need opnion
    By 3tcRob in forum Toyota Garage
    Last Post: 12-22-2010, 08:24 PM
