Results 1 to 10 of 17
Thread: visual difference in L20/L28's??
    Jul 2010
    Litchfield Park ARIDzona
    382
    ok when i bought my car it came with two spare engines, i was told that one is an Original GT-X L20 and the other is an L28 from a Z. these engines are pretty bare, basically only blocks /heads and internals, no carbs/manifolds. what do i need to look for on these to identify aside from removing the oil pans and looking at the pickup?? will the sump be in different places?
    i will probably just keep the entire L2o engine and the L28 head/ crank, but ditch the rest as L28's are very readily available in the USA.
    so can anyone post where the stamp on the block will be and what it will say?? i dont think it will be like SR20's or KA24's, or even honda engines are very easily spotted.
    also i have three different valve covers that all say something different.. is there any valve cover thats more rare than another (besides the S20 that is... HAHA)
    Jul 2010
    382
    upon moving the engines today im pretty sure they are both stamped L20 now, but on one the oil sump is to the front and on one the sump is to the rear..
    on the skyline L20 isnt the sump supposed to be to the back of the engine?
    not sure if i should try to freight BOTH engines to the US now or not??
    Jul 2010
    382
    we had to move BOTH engines to the third floor of my friends ware house and when the lift reached the third floor platform it kind of shimmied and one of the engines rolled right off and landed on his RC drift track one floor below.. havnt looked it over, but luckily no one was under it to get crushed. right now its just buried on destroyed wood and carpet remnants until he can have his mechanic pry it loose. it was a crazy sight to see.
    Northern California
    635
    If you get a copy of the g-works mag. They posted good pictures of an L28 block. I'll try and post pics tom.
    5,530
    Re: visual difference in L20/L28's??
    It's at the top edge of the block (below the head gasket) on the opposite side of the carbs/exhaust. It will say L20 or L28E. :mrgreen:
    Also visually they have different timing covers. The short block engines (L20/L24) only have two bolts at the top of the cover. The tall block L28 has 4.
    Same way you tell the L14/L16/L18 from the L20b.
    Jan 2008
    New Zealand
    156
    As with what 'datsunfreak' said. The block should have a flat surface that stamped below at the #6 end of the block (ie. where the transmission bolts to, underneath where #6 sparkplug is. It will look something like this;
    Skylines are FRONT SUMP. The rear sump you have will be the motor from the FairladyZ.
    Which covers do you have?
    The 'standard' NISSAN OHC in thin font,
    The NISSAN 2000 OHC in the same font,
    NISSAN in big block letters.
    NISSAN in small and TURBO in big block letters.
    They're all variations of the standard shaped cam cover though. A rare cover is the one with a squared section above the cam gear that has "OHC" cast into it. Or "3100" you can imagine why, I'm sure.
    Jul 2007
    Sydney, Australia
    1,653
    It's possible that the engine block stamp is misleading tho. Registration costs are based on capacity in Japan, and so it isn't unusual for the L28 to be ground off and L20 stamped in it place :lol:
    Also the heads on L20 are 30mm inlet port, on L28 it's 36mm. On the plug side of the head, look for a code cast into the ledge under the plug holes, if it sez N42 it's an L28 head.
    Northern California
    635
    Here are some pics from the G-Works. If you need more LMK.
    Northern California
    635
    Few more...
    Sep 2007
    Christchurch, New Zealand
    36
    Quote Originally Posted by kyteler
    Just to add to this, isnt fitment of either front or rear sump all to do with the relation of the suspension setup compared to where abouts the engine sits?
    Eg: a 240/260/280Z and the 1st gen L24E Maxima has the front suspension fairly well forward, so needs a rear sump to clear it, and the Skyline and Laurels have the suspension closer to underneath the firewall so need the front sump fitted.
  1. Need to know the difference..RA40 GT/ST
    By jrockeast85 in forum Toyota Garage
    Last Post: 12-30-2012, 04:52 AM
  2. g-nose difference from oem and aftermarket
    By dice in forum Datsun/Nissan Garage
    Last Post: 09-14-2010, 09:29 PM
  3. Difference between a KE25 and TE27
    By dmg1979 in forum Toyota Garage
    Last Post: 09-14-2010, 08:18 AM
  4. RX-7 Gas tank difference
    By schellerup in forum Mazda Garage
    Last Post: 09-14-2010, 02:54 AM
  5. Spot the Difference
    By rockerben143 in forum Mitsubishi Garage
    Last Post: 05-21-2010, 04:55 AM
